OLC question
Old April 26th 17, 04:56 PM posted to rec.aviation.soaring
Default OLC question
My OLC daily score for the USA seems to be stuck on 22 Apr. I can find later flights by looking at specific regions of the US, but not the main US page. I have tried going through the SSA's website link to the OLC and get the same result. Is it just me, or are others having this problem, and if so what is the solution?
David
ASG29E BV
Old April 26th 17, 05:08 PM posted to rec.aviation.soaring
Renny[_2_]
David
ASG29E BV
David,
This "issue" happened recently and it has happened again....Apparently, it is an OLC problem...I suspect they have watched "Groundhog Day" far too many times... Thx - Renny
Old April 26th 17, 08:34 PM posted to rec.aviation.soaring
JS
David
ASG29E BV
David,
Try switching to Worldwide and back.
Old April 27th 17, 08:49 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Doesn't work for me. I do see that individual regions within the US show current activity (more recent than April 22) if you search by region.
Old April 28th 17, 12:15 AM posted to rec.aviation.soaring
Renny[_2_]
OK..It appears to be working properly now....
Old April 28th 17, 01:31 AM posted to rec.aviation.soaring
Still not for me. It still comes up for 22 Apr. I can see flight added since then but only by going to each individual region.
David
question Dave LaPrise Aviation Photos 3 June 25th 08 12:29 AM
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
STC question John Galban Owning 1 August 9th 03 01:00 AM
