SGS 1-35 add weight to tail for cg relocation
Old May 2nd 17, 04:33 PM posted to rec.aviation.soaring
michael pitoniak
Default SGS 1-35 add weight to tail for cg relocation
team,
anyone successfully add weight to tail? if so how and where.
need to shift CG rearward on my 1-35 C,
many thanks,
mike
Old May 2nd 17, 04:54 PM posted to rec.aviation.soaring
Tony[_5_]
Call Kyle at K&L. He should be able to help.
Old May 2nd 17, 06:53 PM posted to rec.aviation.soaring
BTW. Nothing in the 1-35 manual. But the location of ballast for CG, not water in the wing tanks, changes spin recovery slightly or a lot as well. (We've had all three 1-35 models.)
Old May 4th 17, 02:13 PM posted to rec.aviation.soaring
PGS
On Tuesday, May 2, 2017 at 11:33:57 AM UTC-4, michael pitoniak wrote:
team,
many thanks,
mike
Mike,
I would make a steel tail wheel to replace the rubber one. Did that with one of my wing tip wheels to correct a heavy wing condition (a result of a repair)
Sabre relocation Glenn[_2_] Aviation Photos 0 February 11th 12 08:22 AM
Fiberglass cloth weight vs 'finished' weight Fred the Red Shirt Home Built 12 April 5th 08 04:24 PM
DG300 Tail weight John Schaffer Soaring 3 September 12th 06 09:36 AM
Glider Weight/Wing Loading and determing speed for best L/D for a given weight 65E Soaring 3 January 26th 06 09:26 PM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 04:20 AM
