https://en.wikipedia.org/wiki/Cessna_165
The Cessna Model C-165 Airmaster is a single-engined aircraft manufactured by the Cessna Aircraft Company. The Airmaster played an important role in the revitalization of the Cessna aircraft company in the 1930s after the crash of the aviation industry during the Great Depression. Initial model In the middle of the 1930s, as the Great Depression came to an end, the U.S. economy began to strengthen. This was good news for the Cessna Aircraft Company as Dwane Wallace (Clyde Cessna's nephew who was a recently graduated aeronautical engineer) decided to assist his uncle in building more modern airplanes. The design of the first Airmaster is credited to Wallace, and the first flight of the C-34 model was in June 1935. Not long after introduction of the C-34, Clyde Cessna retired from aircraft-building activity, leaving the company to his nephew. Later models The original Airmaster, the C-34, evolved into more advanced versions of the Airmaster. The C-37 had a wider cabin, improved landing gear and electric flaps. The C-38 had a taller vertical tail, curved main gear legs and a landing flap under the fuselage. Changes common to both the C-37 and C-38 included wider fuselages and landing gear along with rubber engine mounts to hold the 145 hp (108 kW) Warner Super Scarab engine. The final revisions of the C-34 were the C-145 and the C-165, of which 80 were built. On these models, the belly flaps added on the C-38 were removed and the overall length of the fuselage was increased. The only difference between the C-145 and C-165 was the engine horsepower, with the latter having an upgraded 165 hp (123 kW) Warner engine. End of the line It was with the beginning of World War II that the Airmaster line came to an end. The welded tubular fuselage, fabric-covered body, extensive woodwork, wooden wings and radial engines, all characteristic of 1930s-era aircraft technology, became too expensive and slow to produce. The old-style aircraft was quickly replaced with aircraft constructed from aluminium with strut braced wings first seen in the Cessna 120. Role Civil aircraft Manufacturer Cessna Designer Dwane Wallace First flight June 1935 Introduction 1930s Number built 228 The design of the C-34 incorporates characteristics that were borrowed from previous models of Cessna Aircraft. These similarities include the high mounted cantilever wing and the narrow design of the cabin windows.[2] The wings and tail surfaces were composed entirely of wood while the fuselage was structured with steel tubing coupled with wooden stringers and formers. Both C-145 and C-165 models were offered with floats. Specifications General characteristics Crew: 1 Capacity: 3 passengers Length: 24 ft 10 in (7.57 m) Wingspan: 33 ft 10 in (10.31 m) Height: 7 ft 3 in (2.21 m) Wing area: 180 sq ft (17 m2) Empty weight: 1,300 lb (590 kg) Gross weight: 2,220 lb (1,007 kg) Fuel capacity: 35 US gal (29 imp gal; 130 L) Powerplant: 1 × Warner Super Scarab 7-cylinder radial engine, 145 hp (108 kW) Performance Maximum speed: 162 mph (261 km/h; 141 kn) at sea level Cruise speed: 143 mph (230 km/h; 124 kn) Stall speed: 47 mph (76 km/h; 41 kn) Range: 550 mi (478 nmi; 885 km) Service ceiling: 18,900 ft (5,800 m) Rate of climb: 1,000 ft/min (5.1 m/s) * Also... Cessna Model A https://en.wikipedia.org/wiki/Cessna_Model_A The Cessna Model A was a 1920s American high-wing four-seat tourer built by the Cessna Aircraft Company, the first in a long line of high-wing single-engined monoplanes. The first Cessna design built in any numbers was the Cessna Model A, a four-seater with a mixed wood and steel-tube construction with fabric covering. The aircraft was built in a number of variants fitted with different engines. Role Four-seat tourer Manufacturer Cessna Aircraft Company Designer Clyde Cessna First flight 1920s Primary user private owners Number built 83 Model AW Fitted with a 125hp (93kW) Warner Scarab engine, 48 built. One was purchased by Eddie August Schneider in which he set three transcontinental airspeed records for pilots under the age of twenty-one in 1930. * |
Granville Brothers (Gee Bee) Model R pics [15/21] - gee-bee-model-r-1[2].jpg (1/1) | Miloch | Aviation Photos | 0 | June 26th 16 04:11 PM |
Granville Brothers (Gee Bee) Model R pics [08/21] - Gee Bee Model E-Sportster.jpg (1/1) | Miloch | Aviation Photos | 0 | June 26th 16 04:11 PM |
Cessna Citation X Model Aircraft | [email protected] | Piloting | 0 | January 14th 08 02:48 AM |
FA: 1964 CESSNA Model 150 Owners Manual w/Airport form | [email protected] | Aviation Marketplace | 0 | August 1st 05 02:34 AM |
FA: 1964 CESSNA Model 150 Owners Manual w/Airport form | [email protected] | General Aviation | 0 | August 1st 05 02:34 AM |
