Oudie task declaration to PowerFLARM
Old May 12th 17, 02:05 PM posted to rec.aviation.soaring
Tony[_5_]
Default Oudie task declaration to PowerFLARM
I have noticed this year that my Oudie will upload the task to my Portable PowerFLARM but it will not update the pilot name, glider type, contest I'd Etc. The dialog box on the Oudie during task upload indicates it is sending the glider info but the flarm config file does not get rewritten and the igc file reflects whatever the flarm config file.
Thankfully the Sporting Code is not quite as Nazi-ish about this as they were a few years ago and my OO can certify the glider I was flying on the flight.
Anyone have any idea why this is or if there is anything I can do to get it working correctly again?
Old May 12th 17, 02:45 PM posted to rec.aviation.soaring
Matt Herron Jr.
do you have a USB stick plugged in? If so, and it has a config file on it, it will re-install the old config file every time you power up.
Old May 12th 17, 04:04 PM posted to rec.aviation.soaring
Tony[_5_]
And uploading the task from Oudie to PowerFLARM triggers a power cycle...so the answer is to not fly with the SD Card Installed...
Task declaration validity with 302 for US state records [email protected] Soaring 7 August 3rd 14 02:09 AM
Oudie download of task to CAI302 [email protected] Soaring 4 July 17th 13 10:22 PM
PowerFlarm Declaration Karl Kunz[_2_] Soaring 12 June 13th 13 02:08 PM
PowerFlarm flight declaration Bob 7U Soaring 2 November 16th 10 02:58 PM
Help needed with task declaration Stewart Kissel Soaring 2 March 23rd 04 05:43 PM
