A Talking Airspeed Indicator
Old May 17th 17, 05:33 PM posted to rec.aviation.soaring
Soartech
Default A Talking Airspeed Indicator
Last year I was looking for such a device to allow me to montitor my speed more easily on approach so I didn't have to glance at the panel during this critical stage of flight. I found this affordable, small box that plumbs into your pitot line and runs on 12V. It is made in England. I only turn it on for landing so I added a power switch. It is made for headphone use so I added a small amplifier circuit to drive a speaker.(Will supply schematic if you want it.) I am pretty happy with it and thought others might like to know about it. This device should really help pilots avoid the stall-spin on approach problem as well as achieving a low-energy touchdown.
Link: http://www.smartavionics.com/prod-smartass.html
Old May 17th 17, 09:21 PM posted to rec.aviation.soaring
Tom BravoMike
Any influence on the readings of the glider's ASI?
Tom BravoMike
Old May 17th 17, 09:36 PM posted to rec.aviation.soaring
Soartech
No.
Tom BravoMike
Old May 18th 17, 11:19 PM posted to rec.aviation.soaring
Mike the Strike
On Wednesday, May 17, 2017 at 1:36:29 PM UTC-7, Soartech wrote:
No.
Tom BravoMike
I already have too many talking instruments. Gauges (and appliances) should be seen and not heard! https://www.youtube.com/watch?v=LRq_SAuQDec
Old May 18th 17, 11:44 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
No.
Tom BravoMike
Good one!
I have two noise-making instruments -vario and FLARM. My ASI is silent
and mounted where it belongs: top dead centre in the panel.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old May 19th 17, 02:20 AM posted to rec.aviation.soaring
Duster
Aha, finally found out who thought making glass-bottled ketchup worked just fine. Just kidding, but I think an audio-enabled ASI would be a good safety addition in reducing work-load during the most critical phases of flight (as long as one maintains visual instrument scans of course). Might have come in handy for at least some of those low altitude base/final turn accidents? Expensive at ~$300 and wonder if our flight computer software couldn't be modified to include audio warnings (using ASI, not gps input).
Old May 19th 17, 03:23 AM posted to rec.aviation.soaring
Dan Daly[_2_]
"Stall Warning System SP-3
Electronic STALL WARNING SYSTEM designed to meet the requirements of JAR 22..207 and FAR 23.207 as well. Awarded the O.S.T.I.V. prize, being installed on gliders since 1991 and certified in Poland. Easy to install. No aerodynamic burden. Only one additional pressure sensing hole in the nose of the glider, or in the lower surface of the wing of the aeroplane. Ideal for sailplanes, motogliders and ultralight aeroplanes. The device signals close to stall condition in the range between 5 and 10 percent over the stall speed in straight and circling flight over the whole loading and ballast range. You set the alarm threshold only once, individually for your glider. How does it work ? The difference between pressures Pt and Pc is the function of the two variables : speed and angle of attack. The device measures, calculates and detects the moment when the combination of these two parameters informs you about an approaching stall."
You set your own threshold. It squawks when you get there; works well in my SZD-55. http://www.olk.com.pl/indexen.php?bo...roducts&lpx=26 . Takes very little power and panel, and no upkeep.
Why re-invent the wheel?
Old May 19th 17, 03:24 AM posted to rec.aviation.soaring
My LX9000 yells "STALL" a few seconds after touchdown. Did a stall series at altitude last weekend and it missed a few and the rest of the time I was already stalled when I got the warning. I suppose I could spend some time tweaking it, but probably won't.
Old May 19th 17, 05:46 PM posted to rec.aviation.soaring
Paul Agnew
Increased dependence on technology for basic flying skills could lead to poor reversion to manual methods when the tech fails.
Your mileage may vary...
Paul A.
Treasure Coast Soaring Club
Vero Beach, FL
Airspeed indicator ? [email protected] Soaring 7 August 2nd 15 02:32 PM
Looking for a used 57 mm airspeed indicator Scott Alexander[_2_] Soaring 0 October 13th 12 07:28 PM
Airspeed Indicator Strangeness Frank[_1_] Soaring 6 June 9th 08 01:24 PM
Airspeed Indicator problems [email protected] Soaring 6 June 19th 07 02:33 AM
verifying airspeed indicator Heino & Deanne Weisberg Home Built 11 October 22nd 05 07:36 PM
