LX Zeus and PowerFlarm -- Communication Problem
Old May 17th 17, 10:50 PM posted to rec.aviation.soaring
C-FFKQ (42)
Default LX Zeus and PowerFlarm -- Communication Problem
Hopefully someone has been through this exercise (successfully).
I just received my PowerFlarm today and I'm installing it into the panel (that's no problem). The plan is to use the Zeus for the target display.
There's a "Flarm" port on the back of the Zeus, but it's not RJ-45, like the port on the PF (wasn't planning on using the DB-9 harness that came with the PF, no idea where to wire it to the Zeus). However, the CAN port on the Zeus IS RJ-45, so I connected the PF to the Zeus using one of my cat5e LAN cables. The PF powers up, updates and the file it writes out tells me everything is ok.
Unfortunately, it seems that there's no communication between the Zeus and the PF. I'm at home, not near airways, so no targets to see. But I can check the Zeus system status for GPS function. No joy I've left my panel outside with the GPS antenna having a clear view of the sky for half an hour -- plenty of time to get a signal lock. Still nothing on the Zeus.
Anyone have any ideas?
Thanks in advance.
Old May 17th 17, 11:07 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Thanks in advance.
Cumulus Soaring has a Goddard cable for that.
"LXNAV-S7-GPS-PFCore
Cable from the Zeus's FLARM port to the
PowerFLARM's DB-9 connector
The Zeus powers the
PowerFLARM Core with 12V."
Old May 17th 17, 11:20 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
the Zeus.
Questions you need to work out answers for:
1) Does the PF also use an RJ-45 for a CAB-bus connection?
2) Is your CAT5e cable straight of cross-over?
It might be either because CAT5 can be wired either way and
modern switches are generally capable of figuring out whether
the cable is crossed or not and adjusting its internal pin usage.
3) Do your manuals have pin-outs for both the PF and Zeus sockets.
This web page shows CAN-bus pinouts for a variety of connectors including
RJ45 - http://www.interfacebus.com/Can_Bus_...or_Pinout.html
Hopefully answering the questions and using that page that will get you
sorted out: there's enough info in it to let you make up a CAN-bus cable
for almost any set of connectors. Hope you have a DVM for wire tracing
and soldering iron: you don't need an RJ45 crimp because, if you need to
make up a cable you can chop one connector off the RJ45 and solder the
other, non-RJ45, connector onto that end.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old May 17th 17, 11:53 PM posted to rec.aviation.soaring
Dave Nadler
Why not? Did you read the manual?
A CAN bus has nothing to do with the RS-232 connections on FLARM.
You will have been extremely lucky not to have blown up one or
both bits of gear by connecting these two.
Blindly connecting stuff just because they happen to have the
same connector is really, really, really unwise...
Old May 18th 17, 12:29 AM posted to rec.aviation.soaring
C-FFKQ (42)
It had all these lovely plug-ins... and the Zeus manual just says it plugs in (granted, that was for Red-box and mini-Flarm, no specific mention of PowerFlarm).
Yeah... additional research is indicating that.
I'm now looking at the pinout of the PF on the DB-9 and matching it to the CAN bus on the Zeus... I have my friend's RJ-45 crimper out. The joys.
Old May 18th 17, 02:32 AM posted to rec.aviation.soaring
Dave Nadler
One more time: A CAN bus has NOTHING to do with RS-232 NMEA connection.
Do *NOT* connect these.
Old May 18th 17, 09:27 AM posted to rec.aviation.soaring
C-FFKQ (42)
I didn't get that the first time, sorry.
Dave Springford tells me that I should be using the RJ11 port on the Zeus and that it's pinout is the same as the middle 6 pins on the RJ45 from the PF. So, I'll get a RJ11 connector and make the cable.
Too many connectors, not enough brain power sigh
I'll be suggesting some updates to the Zeus manual after this.
Old May 18th 17, 08:30 PM posted to rec.aviation.soaring
I think the Zeus manual is pretty clear - it says the flarm port is an RJ11 using the IGC standard. The IGC standard is very easy to find on the web.
A straight cable with an RJ11 at each end and a RJ121/RJ12 reducer (link below) would also solve the problem.
https://www.jaycar.com.au/medias/sys...geMain-515.jpg
Nick.
PowerFlarm Update Problem John Carlyle Soaring 14 April 15th 15 11:20 PM
I need help with PowerFlarm problem Andy K Soaring 11 July 23rd 14 09:53 AM
Air-to-air communication and the FCC/FAA [email protected] Soaring 9 April 7th 13 12:23 AM
LX Zeus and PowerFLARM Brick Gabriel Duford Soaring 4 October 4th 12 09:48 PM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
