Saab 17
Old May 7th 17, 03:41 PM posted to alt.binaries.pictures.aviation
Miloch
Default Saab 17
https://en.wikipedia.org/wiki/Saab_17
The Saab 17 was a Swedish bomber-reconnaissance aircraft.
The project first started at the end of the 1930s as the L 10 by ASJA, but after
the merger with Saab in 1937 it was renamed Saab 17. The wings were reinforced
to make it possible for use as a dive bomber. Since there was a shortage of
engines the aircraft were flown to their destination, where the engines were
removed and returned for use by the next delivery. The aircraft was also made in
three versions with different engines.
Two prototype L-10 aircraft were ordered, the first being powered by a 880 hp
(660 kW) Nohab-built Bristol Mercury XII and the second by a 1,065 hp (794 kW)
Pratt & Whitney R-1830 Twin Wasp.
The production B 17A used a Swedish-built Pratt & Whitney Twin Wasp, the B 17B a
Svenska Flygmotor AB (SFA)-built Bristol Mercury XXIV, and the B 17C a Piaggio
P.XI. The aircraft could be fitted with wheels, skis or floats. A unique feature
of the Saab 17 was its use of the extended landing gear assembly, with its large
covers, as dive brakes.
Role
Bomber, reconnaissance
Manufacturer
Saab
First flight
18 May 1940
Introduction
1942
Retired
1955, Sweden
1968, Ethiopia
Status
Retired
Primary users
Swedish Air Force
Ethiopian Air Force
Finnish Air Force
Austrian Air Force
Produced
1941–44
Number built
323
The first test flight was on 18 May 1940 and first deliveries to the Flygvapnet
(Swedish Air Force) were in 1942. However, the development of the turbojet meant
it had a short service history, but when the B 17 ended Swedish service in
1947–50, 46 were sold to Ethiopia, remaining in service until 1968. Two B 17As
were sold to Finland in 1959 and 1960, serving as target tugs for the Finnish
Air Force, both succumbing to accidents fairly quickly. For some months from
very early 1945 15 B 17A were issued to DANFORCE (Danish Brigade of 5000 men in
Sweden). However, as things unfolded with the German surrender – there was no
use for these in the liberation of Denmark, and the aircraft were returned to
the Flygvapnet a couple of months after the German surrender.
Specifications (B 17C)
General characteristics
Crew: two
Length: 10 m (32 ft 10 in)
Wingspan: 13.7 m (44 ft 11 in)
Height: 4.5 m (14 ft 9 in)
Wing area: 28.5 m2 (307 sq ft)
Empty weight: 2,680 kg (5,908 lb)
Gross weight: 3,870 kg (8,532 lb)
Powerplant: 1 × Piaggio P.XIbis R.C.40D 9 cyl. air-cooled radial piston engine
Propellers: 3-bladed Piaggio P.1001 variable pitch propeller
Performance
Maximum speed: 435 km/h (270 mph; 235 kn)
Cruise speed: 370 km/h (230 mph; 200 kn)
Landing speed: 125 km/h (78 mph; 67 kn)
Range: 1,700 km (1,056 mi; 918 nmi)
Service ceiling: 9,800 m (32,200 ft)
Rate of climb: 10 m/s (2,000 ft/min)
Wing loading: 139 kg/m2 (28 lb/sq ft)
Power/mass: 0.220 kW/kg 0.14 hp/lb
Armament
Guns:
2× 8 mm (0.315 in) (Kulspruta) Ksp m/22F machine gun machine guns, fixed
forward-firing
1× 8 mm (0.315 in) Ksp m/22R machine-gun flexibly mounted in the rear cockpit
Bombs: 700 kilograms (1,500 lb) of bombs
Saab Gripen, Concluded - Saab Gripen 78.jpg (1/1) Mitchell Holman Aviation Photos 0 August 28th 08 01:14 PM
Saab Gripen, Concluded - Saab Gripen 77.jpg (1/1) Mitchell Holman Aviation Photos 0 August 28th 08 01:14 PM
Saab Gripen, Concluded - Saab Gripen 75.jpg (1/1) Mitchell Holman Aviation Photos 0 August 28th 08 01:14 PM
Saab Viggen, concluded - Saab Viggen 54.jpg (1/1) Mitchell Holman Aviation Photos 2 August 19th 08 10:50 PM
Saab Viggen, concluded - Saab Viggen 46.jpg (1/1) Mitchell Holman Aviation Photos 0 August 18th 08 01:10 PM
