In filling out my FAA form for my USA pilot's certificate, I note that they
have spaces for not only total hours and number of flights but also cross-country flight time. The only problem is that the Federal Aviation Regulations (FARs) do not appear to define cross-country flying as it applies to gliders. Local FAA gurus were unable to offer any other definition than the one applicable to airplanes, which requires a landing at a remote airfield. Can any other US pilots throw light on this? It might also be interesting to hear from Europeans what their official definitions are. Mike ASW 20 WA |
"Michael Stringfellow" wrote:
In filling out my FAA form for my USA pilot's certificate, I note that they have spaces for not only total hours and number of flights but also cross-country flight time. The only problem is that the Federal Aviation Regulations (FARs) do not appear to define cross-country flying as it applies to gliders. Local FAA gurus were unable to offer any other definition than the one applicable to airplanes, which requires a landing at a remote airfield. Can any other US pilots throw light on this? It might also be interesting to hear from Europeans what their official definitions are. Mike ASW 20 WA Where I trained they said you were on a cross country whenever you needed more altitude than you had to get back to your home field. |
Not sure what the "official" designation is; however, I think a
generally accepted definition of cross country would be any flight that takes you beyond gliding distance of the home field. This would apply wether you return to the home field or not. My 2 cents worth. David Martin ASW27 BV |
"Michael Stringfellow" wrote in message news:kQuUb.15985$EW.8868@okepread02...
In filling out my FAA form for my USA pilot's certificate, I note that they have spaces for not only total hours and number of flights but also cross-country flight time. The only problem is that the Federal Aviation Regulations (FARs) do not appear to define cross-country flying as it applies to gliders. Local FAA gurus were unable to offer any other definition than the one applicable to airplanes, which requires a landing at a remote airfield. Can any other US pilots throw light on this? It might also be interesting to hear from Europeans what their official definitions are. Mike ASW 20 WA If you read the FARs, under aeronautical experience, for powered flight, you will see some requirements for, I am looking it up for you right now: 3 hrs of cros country flight training in a sgl engine aircraft.;3 hrs of nightflight training in airplanes including one of over 100 miles distance.....There they are spelling it out for you Fly 100nm. Then they want 5 hrs solo X-Country, of wich one flight has to be at least 150 mi long etc. The FAA did not always specify.....to be done in an sgl engine airplane, 20 years ago you could count your Glider X-Country towards your power license. If it was long enough! Still, the FAA specifies the above and a couple of other hrs to be flown in an airplane , which means, that about 25 hrs of glider time can be applied towards the needed time of still only 40 hrs for the private license airplane. Read FAR 61.109 my book is the 2001 issue! Not sure whether I answered your question. How does the FAA define X-Country different between gliders and airplanes?? Dieter Bellanca Viking |
FAR 61.1(b)(3)(ii)(B), for the purpose of meeting aeronautical experience
requirements, "that includes a point of landing that was at least a straight line distance of more than 50 nautical miles from the original point of departure." Another section of the FARs pt 61 tell you that a student pilot is "cross country" if more than 25nm from his home airport, but that does not count as x-c time, he just needs "special permission" to be more than 25nm away. So, 50nm is the rule, you can log x-c if you take off and land 5nm away... but you can't "count" it to meet a requirement towards additional ratings unless the landing is more than 50nm away.. and that means a landing, can't just circle the point (airport or flag pole) and return without landing. It will not count for meeting rating qualification requirements. BT "soarski" wrote in message om... "Michael Stringfellow" wrote in message news:kQuUb.15985$EW.8868@okepread02... In filling out my FAA form for my USA pilot's certificate, I note that they have spaces for not only total hours and number of flights but also cross-country flight time. The only problem is that the Federal Aviation Regulations (FARs) do not appear to define cross-country flying as it applies to gliders. Local FAA gurus were unable to offer any other definition than the one applicable to airplanes, which requires a landing at a remote airfield. Can any other US pilots throw light on this? It might also be interesting to hear from Europeans what their official definitions are. Mike ASW 20 WA If you read the FARs, under aeronautical experience, for powered flight, you will see some requirements for, I am looking it up for you right now: 3 hrs of cros country flight training in a sgl engine aircraft.;3 hrs of nightflight training in airplanes including one of over 100 miles distance.....There they are spelling it out for you Fly 100nm. Then they want 5 hrs solo X-Country, of wich one flight has to be at least 150 mi long etc. The FAA did not always specify.....to be done in an sgl engine airplane, 20 years ago you could count your Glider X-Country towards your power license. If it was long enough! Still, the FAA specifies the above and a couple of other hrs to be flown in an airplane , which means, that about 25 hrs of glider time can be applied towards the needed time of still only 40 hrs for the private license airplane. Read FAR 61.109 my book is the 2001 issue! Not sure whether I answered your question. How does the FAA define X-Country different between gliders and airplanes?? Dieter Bellanca Viking |
So by your definition you can do a 1000km triangle flight without going
cross country. Just so long as you land back at the take-off airfield. Out of gliding range of the airfield is usually the common sense definition of cross country. I'd qualify that with - If you have to navigate to get home ( ie: read a map or GPS, negotiate airspace ). Ian |
cross country. Just so long as you land back at the take-off airfield. No... It's not my definition... it is the FAR... Any student is X-C if more than 25nm from home. But he can't log that 25 or 20nm trip as X-C time towards his rating.. he needs to be at least 50nm and LAND OUT. for the "PURPOSE OF LOGGING REQUIRED CROSS COUNTRY TIME TOWARDS AN ADDITIONAL RATING. And to COUNT time for ADDITIONAL ratings as cross country.. you have to LAND OUT. YOU can LOG anything you want to.. a 5nm out and back as X-C if you so desire. You just count it towards any X-C requirement for an additional rating. Luckily for gliders X-C time is not a requirement.. but it is for AIRPLANE, and you'll find that the FAR also requires said LOGGED X-C time towards the Airplane Pvt and Commercial Ratings to be LOGGED in an AIRPLANE. Not a glider. So... for COUNTING purposes, you need at least 50nm and a land out to count it towards any requirement for additional ratings. BTW, this is US FAR rules... BT |
At 02:30 06 February 2004, Btiz referenced:
FAR 61.1(b)(3)(ii)(B), for the purpose of meeting aeronautical experience requirements... Uhm... the cited FAR paragraph actually refers to a cross country definition in the context of 'experience requirements' established for private, commercial or instrument pilot certification in aircraft other than rotorcraft... and there are no cross country requirements established for any level of glider pilot certification. The Part 61 FAQ is mute on this topic, but I believe 61.1(b)(3)(i) is the applicable paragraph and it defines 'Cross country time' as 'time acquired during a flight... - conducted by a person who holds a pilot certificate - conducted in an aircraft - that includes a landing at a point other than the airport of departure; and - that involves the use of dead reckoning, pilotage, electronic navigation aids, radio aids, or other navigation systems to navigate to the landing point.' Thus, FAR-wise, a land-out a few miles away from home may involve 'cross country time' in a glider but a successful closed course glider flight of several hundred miles does not appear to be cross country flight time at all! Your insurance company probably has other ideas... Judy |
so true Judy...
BT "Judy Ruprecht" wrote in message ... At 02:30 06 February 2004, Btiz referenced: FAR 61.1(b)(3)(ii)(B), for the purpose of meeting aeronautical experience requirements... Uhm... the cited FAR paragraph actually refers to a cross country definition in the context of 'experience requirements' established for private, commercial or instrument pilot certification in aircraft other than rotorcraft... and there are no cross country requirements established for any level of glider pilot certification. The Part 61 FAQ is mute on this topic, but I believe 61.1(b)(3)(i) is the applicable paragraph and it defines 'Cross country time' as 'time acquired during a flight... - conducted by a person who holds a pilot certificate - conducted in an aircraft - that includes a landing at a point other than the airport of departure; and - that involves the use of dead reckoning, pilotage, electronic navigation aids, radio aids, or other navigation systems to navigate to the landing point.' Thus, FAR-wise, a land-out a few miles away from home may involve 'cross country time' in a glider but a successful closed course glider flight of several hundred miles does not appear to be cross country flight time at all! Your insurance company probably has other ideas... Judy |
Judy Ruprecht wrote in message news:bvv7p1
but a successful closed course glider flight of several hundred miles does not appear to be cross country flight time at all! It counts as qualifying cross country time for the ATP rating. ATP cross country time does not require a landing at the remote point. (iv) For the purpose of meeting the aeronautical experience requirements for an airline transport pilot certificate (except with a rotorcraft category rating), time acquired during a flight -- (A) Conducted in an appropriate aircraft; (B) That is at least a straight-line distance of more than 50 nautical miles from the original point of departure; and (C) That involves the use of dead reckoning, pilotage, electronic navigation aids, radio aids, or other navigation systems. I asked AFS 600 what was meant by appropriate aircraft, and what were inappropriate aircraft. I was told they had no idea what para (A) meant since there were no inappropriate aircraft and yes, gliders qualified. BTW I was able use 25 hours of glider cross country (flights where I landed more than 50nm from origin) toward the experience required for airplane commercial. Those landout flight finally got some credit and saved me 25 expensive hours in airplanes. Andy |
Cross country time | clyde woempner | Owning | 5 | February 2nd 05 10:36 PM |
Cross Country Logging time | Jim | Piloting | 14 | April 21st 04 09:58 PM |
Any tutorials like Al Pelitires "Round Robins" ot Alfred Poors " Cross Country"... | [email protected] | Simulators | 0 | February 6th 04 09:01 PM |
US cross country flight | S Narayan | Instrument Flight Rules | 0 | January 7th 04 02:58 PM |
US cross country flight | S Narayan | Piloting | 0 | January 7th 04 02:58 PM |
