Gordo and Mitch record attempt
Old June 10th 17, 03:08 PM posted to rec.aviation.soaring
Frank Whiteley
Default Gordo and Mitch record attempt
http://glideport.aero/map?p=GlideRegion:4
http://www.recordcourier.com/news/gl...-downwind-run/
Old June 10th 17, 03:20 PM posted to rec.aviation.soaring
Frank Whiteley
Gordo and Mitch both have InReach
https://share.delorme.com/MitchPolinsky
https://share.delorme.com/GordonBoettger
Old June 10th 17, 05:54 PM posted to rec.aviation.soaring
Tony[_5_]
http://flightaware.com/live/flight/N55LK
Flight Aware tracking is doing very good, practically up to the second. They just started climbing near Wells, NV...
Old June 10th 17, 06:19 PM posted to rec.aviation.soaring
Dan Daly[_2_]
HRRR looks wavy. https://rapidrefresh.noaa.gov/hrrr/H...ain=t1&adtfn=1
Old June 10th 17, 10:27 PM posted to rec.aviation.soaring
Still a oft! Still stuck in the valley at Logan. If they manage to climb away and keep going this will go down as one of the most epic low saves in history
Old June 11th 17, 12:53 AM posted to rec.aviation.soaring
Gordon Boettger
Well Mitch and I safely down at Logan after a quick run across NV. Had to get high on the north end of the Ruby range (27.5K) to get across a large band of undercast (Max wind was 103kts near Winnemucca). Made for an interesting looong glide (150 nm) over the fluffy white stuff to the Logan valley across the Great Salt Lake. The airmass went unstable in the Logan area with low level cu and very light winds across the ridgetops. We dug around in the valley in choppy thermals to 9k weighing our options and after reviewing wx on the ipad it was evident that the wave was no more. After overheating for a few hours a few thousand feet over the ground in heavy wave gear it was time to lower the gear. Great run while it lasted and always a blast. Thanks Fred Lasor for the tow and Dave for crewing. It's REALLY tough to get the wx to line up across that distance. One area where the wave is needed and it's not there and it's game over. Hell, it's still a blast and we'll get it someday.
Cheers to all that enjoyed watching.
Gordon
Gordon Boettger Glider Record Attempt - Mon 03/21/2016 WaltWX[_2_] Soaring 34 March 22nd 16 04:55 AM
Mitch Polinsky - on FG to Chadron, NE - Free Distance Record WaltWX[_2_] Soaring 10 July 27th 14 06:10 AM
Boettger Distance Record Attempt Saturday Mar 29 WaltWX[_2_] Soaring 10 March 29th 14 10:03 PM
Best Glider for Altitude Record Attempt? Jerome Conners Soaring 24 December 17th 03 10:54 AM
Edwards air show B-1 speed record attempt Paul Hirose Military Aviation 146 November 3rd 03 05:18 PM
