HELP: Towout gear for a PW5
Old February 17th 04, 12:43 PM
JD
Default HELP: Towout gear for a PW5
Hello,
Has anyone got any plans or photos or ideas for towout gear to suit a PW5. I
would appreciate anything that would be helpful for ideas.
Looks like I may have to make up a set for my Club.
Thank you in advance.
Regards
Jon Dixon
Beverley Soaring Society
Old February 17th 04, 03:11 PM
Larry Pardue
In article , "JD" wrote:
Hello,
Regards
Jon Dixon
http://bielsko1.com/
Click on accessories and then click on the top picture. It is a rigid
towbar that has a zigzag to clear the tailwheel . I have it and it works
real well.
Larry Pardue 2I
Old February 17th 04, 06:27 PM
JohnD
Hi Jon,
The tail mounting tow bar is only available by special order, if at
all. We have changed over to a nose mounted tow bar which works very
well. It connects via the tow hook and the main-gear axle. I will send
you a picture by separate/direct email. with pricing etc.
As for assembly I use an 'Udo' rig which works excellently for one-man
assy. Let me know if you need his web address. He advertises in
Soaring and his product, while a bit pricey, is exceptional.
I also have other accessories available for upgrading the Smyk with
some of the B-1 PW5 improvements. Seat with integral headrest,
apholstery, larg instrument panel, etc.
End of advertisement! Please contact me for additional details and
products.
John Downing
Downing Sailplanes
www.downingsailplanes.com
"JD" wrote in message ...
Hello,
Regards
Jon Dixon
Old February 18th 04, 02:26 AM
Bob C
Check out MM Fabrication at http://www.mmfabrication.com
Mark makes sailplane trailers, one man rigs carts,
towout bars, wing wheels, and just about anything else
you can dream up around an airport. His towout rigs
run on independent wheels, and don't torque the tailboom
like the German designs. I know he made a tow rig
for one of our local PW-5's a while back. If I remember
right, it's trickier than most due to the funny tailwheel
extension.
At 22:48 17 February 2004, Johnd wrote:
Hi Jon,
order, if at
which works very
axle. I will send
etc.
for one-man
in
the Smyk with
headrest,
details and
products.
John Downing
Downing Sailplanes
'JD' wrote in message news:...
Hello,
ideas.
Regards
Jon Dixon
Old February 18th 04, 03:40 PM
JD
Thank you for your responses. Its appreciated.
Jon
Hello,
I
Regards
Jon Dixon
Old February 19th 04, 07:48 PM
303pilot
If you're towing out on grass, a rope and a wing dolly are all you need.
Paved surfaces require a bit more kit.
Brent
Hello,
I
Regards
Jon Dixon
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 12:35 AM
