Trailer Light Troubleshooting
Old June 26th 17, 05:53 PM posted to rec.aviation.soaring
George Haeh
Default Trailer Light Troubleshooting
Tested lights after pulling trailer out of sheltered winter storage.
Taillights not
working; turn and brake lights OK. No problem driving to field in daylight.
Pulled out the meter and found 0V at the car end connector. No taillights
on
the car. Replaced fuse. Still no taillights on trailer, but 12+V at car
connector.
Opened up trailer connector. The taillight socket had been pushed in so
that
there was no contact with the pin on the car end. Removed wire and used
Jorgensen clamp to bring socket back to face of connector.
Found waxy residue, courtesy some small creature, in socket and removed
with hand held drill bit.
Hint: Tape over connector. Usually the hitch is covered, but something
found
its way in.
Side Marker Bulb replacement found in local auto supply store.
Old June 26th 17, 06:39 PM posted to rec.aviation.soaring
Tony[_5_]
You now have a silver badge in trailer wiring. Congrats!
Old June 26th 17, 06:42 PM posted to rec.aviation.soaring
Tony[_5_]
congrats you have earned a silver badge in trailer wiring!
trailer light module issues Brad[_2_] Soaring 5 August 20th 14 03:10 AM
Trailer Light Replacement olddogcirrus Soaring 2 June 18th 09 05:30 PM
Vertex VXA-150 troubleshooting JS Soaring 2 June 5th 09 12:17 AM
troubleshooting com's transmission jan olieslagers[_2_] Home Built 2 April 13th 09 02:39 AM
Cobra Trailer - tail light cover Thomas Milko Soaring 9 February 8th 05 01:48 AM
