Vintage Brake upgrade-JJ or anyone else who knows
Old March 3rd 04, 04:26 AM
Stewart Kissel
Default Vintage Brake upgrade-JJ or anyone else who knows
What is it that these guys do to improve braking?
Assuming all ships could use help, are some (say a
Ventus) more improved then others? How much $. Thank
you.
Old March 3rd 04, 04:47 AM
Mark Navarre
you.
Reline the shoes with higher performance friction material, and "arc" the new
lining to fit the drum diameter. Have not had my ship done (yet) but am
strongly considering it.
Mark Navarre
ASW-20 OD
California, USA
Old March 3rd 04, 05:12 AM
Greg Arnold
I just had this done. $240. Haven't put the wheel back on the glider
yet, so I don't know if it was worth it.
you.
Mark Navarre
ASW-20 OD
California, USA
Old March 3rd 04, 05:06 PM
John Shelton
Where did you get it done, Greg? Most shops won't touch it now for OSHA
reasons. Reply privately, if you wish.
It works on every other kind of vehicle I had it done to back in the drum
brake days.
"Greg Arnold" wrote in message
news:EPd1c.10206$Zp.1082@fed1read07...
you.
the new
Mark Navarre
ASW-20 OD
California, USA
Old March 3rd 04, 05:24 PM
Stewart Kissel
John-
Vintage Brake, Sonora 209-533-4346
I googled them but only found dead links.
it now for OSHA
to back in the drum
brake days.
'Greg Arnold' wrote in message
back on the glider
you.
material, and 'arc'
the new
Mark Navarre
ASW-20 OD
California, USA
Old March 3rd 04, 05:27 PM
Greg Arnold
http://www.vintagebrake.com/
Stewart Kissel wrote:
John-
it now for OSHA
to back in the drum
brake days.
back on the glider
you.
material, and 'arc'
the new
Mark Navarre
ASW-20 OD
California, USA
Old March 3rd 04, 06:00 PM
Bob Kuykendall
Earlier, Stewart Kissel
you.
The "gang of four" for which I delivered brakes to Mr. Morse all seem
happy. When I visited his shop, he seemed knowledgable and methodical.
So far as I know, what he did for the Gang was:
* Inspect all parts for cracks or defects. One of the four iron drums
had lateral cracks near the crenelations that lock it into the
aluminum wheel half. A used replacement wheel half had to be secured
(thanks, JJ).
* Replace the brake shoes with ones having a different compound that
seems more amenable to lighter actuation forces.
* Re-bush the actuation cam pivot if necessary for greater precision
and lower friction.
* Re-bush the backing plate axle hole if necessary to keep the shoes
aligned with the drum under braking forces.
* Turn the brake drum on a lathe with the wheel halves joined and
bolted. It appears that Tost turns their drums using only the wheel
half that contains the drum. But when the halves are joined, the
forces applied by the bolts that secure them together distorts the
drum slightly.
* Turn the brake shoe pairs on a lathe to match their contact surface
to the arc of the drum. The stock shoes don't seem to fit very well in
this regard.
I believe that the average charge for the gang of four was on the
order of $150 or less, depending on what was required.
The Vintage Brake Web site is:
The tips page has a lot of good advice applicable to the Tost units.
Thanks, and best regards to all
Bob K.
http://www.hpaircraft.com/hp-24
Old March 3rd 04, 06:33 PM
JJ Sinclair
The bad news is, you still can't honk-on the brakes doing 40 knots. If you do,
you will probably crack the drum. Guess how I know?
I keep everything adjusted up snug and try to only apply the brake below 20
knots.
(thanks, JJ).
JJ Sinclair
ken ward
you.
To start with, Michael at Vintage Brake has a primary business of doing
drum brakes for vintage motorcycle racers. This means he has a lot of
experience separating inferior mechanical brake assemblies from quality
ones, he has a large assortment of pad materials on hand, he gets a lot
of feedback from the racers about what works and what didn't, so
ultimately he's got a good grasp of all the variables involved in
picking a compound to match the mechanism and the application.
So, I sent him my LAK-12 main wheel assembly, as the brakes just weren't
up to the task of adequately slowing down a 1000# glider. Although my
glider is Experimental, he won't reject other types; it's up to you and
your mechanic to know what you can/can't do to your glider.
He looked it over, and says the brake components are strong, well made,
good materials used, etc; I think it comes straight out of a Blanki. We
then discussed the typical operating conditions such as runway surface,
temperature, wet/dry, weight. He also wanted cable length and
dimensions of the brake lever pivot assembly.
After all that, he recommended a pad material suited to stopping
something heavy, low duty cycle, no glazing. He installed the new pad
material on the existing shoes, cleaned and examined all pivoting parts,
made sure the drum itself was smooth, then arced the pads to exactly fit
the drums. Total cost was about $150.
What I found was vastly improved braking. It worked great time after
time, with no fading. Only drawback was that it worked a little *too*
well, as vigorous braking at low speeds would lift the tail off the
ground. I spoke with him and he recommended removing material from the
leading edge of the pads, 0.5" at a time, just enough to keep the pad
off the drum.
This improved the situation, but I feel it's really more of an issue
about where the brake is located with reference to the CG. Above
10-15kts full back stick keeps the tail planted, even with full brakes.
Below that speed the tail starts coming up. Some say SZDs exhibit the
same behavior. I'm going to take another 0.5" off this winter and put
on a new tire.
Ken
San Jose, CA
Old March 3rd 04, 06:43 PM
Stewart Kissel
Good answers guys-
JJ's response got me thinking. Because I have greater
elevator authority at higher speeds, I apply much harder
brake when moving fast knowing I can keep the tail
down with back stick. But it sounds like that may
be tough on the drum.
you.
business of doing
he has a lot of
from quality
hand, he gets a lot
didn't, so
involved in
brakes just weren't
Although my
it's up to you and
glider.
strong, well made,
out of a Blanki. We
as runway surface,
length and
to stopping
the new pad
all pivoting parts,
pads to exactly fit
great time after
a little *too*
the tail off the
material from the
leading edge of the pads, 0.5' at a time, just enough
to keep the pad
off the drum.
more of an issue
the CG. Above
with full brakes.
SZDs exhibit the
same behavior. I'm going to take another 0.5' off
this winter and put
on a new tire.
Ken
San Jose, CA
Lightspeed: Upgrade 25XL w/Cell Adaptor or Upgrade to 30 3G Andrew Gideon Products 9 August 20th 04 08:36 AM
Goodyear Brake Pucks - Cheap! Ron Wanttaja Home Built 7 July 16th 04 06:45 AM
Building the Po' Boy Bending Brake Veeduber Home Built 14 March 1st 04 06:15 PM
Cobratrailer&brakes Greg Arnold Soaring 5 October 6th 03 03:14 PM
Brake caliper flange Stealth Pilot Home Built 5 July 7th 03 04:19 PM
