Will I fit?
Old March 5th 04, 05:27 AM
c hinds
Default Will I fit?
I am 6'3" 205 lbs. and currently shopping for a sailplane. I fit OK in
the SGS-1-26, 2-33, Puchacz and can squeeze into a Grob 102 with about
1/2" of clearance to the canopy.
What about Libelle, ASW-15b, DG100, Standard Cirrus, Jantus B ? You
know, all of those "other" sailplanes.
Any and all responses appreciated.
Clark
Old March 5th 04, 05:45 AM
Marc Ramsey
no, maybe, yes, yes, if you mean janus B front no, back yes, if jantar,
yes for most models.
Old March 5th 04, 03:45 PM
Wallace Berry
Wide shoulders and/or a long torso are problems in the Libelle. If you
have long legs and are relatively slim, you will fit in the Libelle just
fine. Best to have a thin packback chute like a National. Use the
minimum seat cushioning you are comfortable with. Libelle's have lots of
leg room. The rudder pedals adjust pretty far forward.
All the 201 Libelles that I have seen have the "high" canopy. I have
both the high and low "racing" canopies for my 301. The high canopy
provides significantly more headroom (although I fly with the low canopy
because it looks so kewl).
Old March 5th 04, 06:00 AM
BTIZ
I'm 5'10" and 200#, I can "fit" in the Libelle with a good shoe horn and I
have flown by friends on occasion.. but not to own one.
The fit check, across the shoulders with the canopy, and, with the canopy
on, can you pull your elbow back to get full deployment on the spoiler?
BT
"c hinds" wrote in message
om...
Clark
Old March 5th 04, 06:12 AM
tango4
5'10" 240lbs and with the seat back removed and by dropping my shoulders
below the canopy line I can fit and fly the libelle comfortably!
Ian
"BTIZ" wrote in message
newsPT1c.13174$id3.3006@fed1read01...
BT
om...
Clark
Old March 5th 04, 06:49 AM
goneill
The cirrus ,nimbus 2,ventus,and the mosquito,mininimbus, LS3 will fit even
me when
when I was 125kgs so you are smaller than me so you should not have a
problem.
With your extra height just take out the seatback and use cushions to set
yourself up
properly and if you need more room for your length have a parachute harness
made
and have the chute in a purpose made pack that fits behind your head
attached to the
spar .That was the rig used by someone 6'4"
om...
Clark
Old March 5th 04, 07:03 AM
Bruce Greeff
Clark
I am same height, and heavier (108kg or 235lbs).
Fit in the Std Cirrus is good, I even have some free headroom, but not much.
Trick is to have a flat pack parachute. I only have two problems from a comfort
point of view. My shins take a beating on the instrument panel every time, and
the Drager oxygen mixer the factory fitted (way back in 1970) on the right hand
side of the cockpit leaves bruises all over my right upper arm if it is rough.
(Those cirrus wings are stiff)
YOu will find visibility is a little limited for the over 6' types, because your
head is under the canopy hoop. The advantage I suppose is you can get your head
out of the sun.
One thing to check is whether your feet fit - there is not a huge amount of
space up front, and even my size 8 feet are forced into a toe in posture.
So you will fit, but will you enjoy it? - my experience is, it is a nice plane
to fly and own with a very good and active community of pilots.
Old March 5th 04, 09:19 AM
David Hodgson
At 06:18 05 March 2004, Bruce Greeff wrote:
c hinds wrote:
I am 6'3' 205 lbs. and currently shopping for a sailplane.
I fit OK in
Grob 102 with about
1/2' of clearance to the canopy.
Jantus B ? You
know, all of those 'other' sailplanes.
Clark
You wont have any problem fitting in to a Dg100
Old March 5th 04, 01:47 PM
Owain Walters
I am 6'2'. I fit in my libelle with absolutely no problems.
I fit OK in
Grob 102 with about
Jantus B ? You
Clark
Old March 5th 04, 02:02 PM
tango4
Yeah, but you're a scrawny little bloke!
Ian
"Owain Walters" wrote in
message ...
I fit OK in
Grob 102 with about
Jantus B ? You
Clark
