Configuring PF Logger
Old July 16th 17, 02:55 AM posted to rec.aviation.soaring
kinsell
Default Configuring PF Logger
Hi Dave,
Look at page 9 of this document:
https://www.cumulus-soaring.com/flar...FLARM-Tips.pdf
In the PF config file, Remde has a line: $PFLAC, S, Pilot, Remde
So this must be the right place to configure it.
However, my file, made with the configuration tool, has no such line.
I'm not currently using the logger.
Why don't you look at your file on your USB stick, and either edit it or
add it if necessary. Use Notepad or Gedit, don't use Word or other
fancy editor. Or send it to me and I can do it. Don't try using the
config tool, you have to enter every value each time, and it's easy to
make mistakes.
Dave
IGC Logger V2.07 is available [email protected] Soaring 0 March 20th 14 01:46 PM
logger rec.aviation.soaring[_2_] Soaring 1 June 26th 11 11:57 AM
Looking for a Logger [email protected] Soaring 0 August 3rd 06 05:47 PM
Ted, your LX logger......... [email protected] Soaring 6 June 26th 06 04:21 PM
Logger Ralf S. Soaring 3 February 21st 04 04:49 AM
