Looking to buy a wing rigger.
Old July 17th 17, 10:03 PM posted to rec.aviation.soaring
Marcin S
Default Looking to buy a wing rigger.
Let me know if you have one for sale.
Marcin
Old July 17th 17, 10:14 PM posted to rec.aviation.soaring
Ron Gleason
Marcin
http://www.mmfabrication.com/wingrigger
Old July 18th 17, 11:50 PM posted to rec.aviation.soaring
Sean Franke
Marcin
I have a two year old IMI wing rigger, $700. Upgraded to their new Power Rigger
http://wingsandwheels.com/imi-one-ma...ng-system.html
Sean Franke
Old July 19th 17, 03:33 AM posted to rec.aviation.soaring
Marcin S
I need the one man rigger for an Asw 20.
You most likely have the wing saddle for a modern 15/18 m glider?
Marcin
Old July 19th 17, 02:13 PM posted to rec.aviation.soaring
Sean Fidler
The IMI universal mentioned above would work perfectly. An ASW20 is actually fairly "modern" and the new wings are only marginally smaller. But if you read the description this has been thought through and described.
The following paragraph comes from the used IMI link above. I'm assuming you didn't read it yet (last paragraph of the description)...
"The universal one man rigging system (OMRS) WORKS WELL ON ALL 15/18 meter gliders. It accomodates older airfoils where the modern 15/18 m OMRS will not. The OMRS for modern 15/18 m gliders has a flatter holder only working with modern airfoils. - See more at: http://wingsandwheels.com/imi-one-man-rigging-system.html#sthash.zs8eUGv7.dpuf"
Good luck.
Looking for a wing rigger for an asw 20 Marcin S Soaring 1 July 10th 17 02:21 AM
Ka6 wing rigger James Koper Soaring 2 June 22nd 17 03:23 PM
Wing Rigger Dan Marotta Soaring 2 September 3rd 16 02:54 PM
Wing Rigger FS Ron Gleason Soaring 2 December 5th 13 05:36 PM
Looking for a used wing rigger / one man rigger .... [email protected] Soaring 0 November 6th 13 06:02 PM
