GOES-16 Site for Satellite Imagery and Animation- realearth.ssec.wisc.edu
Old July 30th 17, 12:29 AM posted to rec.aviation.soaring
WaltWX[_2_]
Default GOES-16 Site for Satellite Imagery and Animation- realearth.ssec.wisc.edu
ACCESS TO 0.5KM VISIBLE IMAGERY!
I've found a University of Wisconsin GOES-16 tiled access site to various imager channels. Try this:
http://realearth.ssec.wisc.edu/?prod...mationspeed=50
Manually change the URL with BAND02 (for visual 0.5km imagery - 0.64micro red channel) to BAND14 (window channel IR) at night.
It appears you can pan/zoom all over the satellite view and set the number of frames to animate. I'm watching a high resolution animation right now of 10 frames. In the upper left hand corner, you can select "Google" "Terrain" and check label on to overlay geo referencing.
The GOES-16 imagery is every 15 minutes.
Note, that it does not appear one can change the imager channel number (BAND) using the web interface. Just change the channel (BANDXX) in the url.
Not bad... I can really see the difference in detecting isolated cu fragments between 0.5km and 1km resolution. Also, dynamic range of visible imagery is much improved.
Walt Rogers WX
Old July 30th 17, 02:59 AM posted to rec.aviation.soaring
Paul Agnew
Thanks. I've been experimenting with this site, too. The resolution is remarkable.
http://weather.cod.edu/satrad/exper/
Paul A.
Old July 30th 17, 11:09 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
On Saturday, July 29, 2017 at 4:29:36 PM UTC-7, WaltWX wrote:
Thanks for the pointer Walt. Very cool.
Is there a translation of what the different imager channels correspond to - and how many channels there are?
Will be a great tool. Wish you could get access to it as a FIS-B (or similar) service and import it in real time straight onto a glide computer.
Someday :-)
9B
Walt Rogers WX
Old July 31st 17, 05:38 AM posted to rec.aviation.soaring
WaltWX[_2_]
Someday :-)
9B
Note, that it does not appear one can change the imager channel number (BAND) using the web interface. Just change the channel (BANDXX) in the url..
Walt Rogers WX
Yes, just Google search GOES-16 IMAGER CHANNELS
Walt WX
Source for previous (24 hour) visible satellite imagery [email protected] Soaring 10 August 14th 15 07:32 PM
Satellite Imagery of Eastern US user Soaring 13 January 23rd 07 07:28 PM
Keyhole satellite imagery and GA Patrick Pohler Piloting 10 November 27th 04 10:03 PM
Different Aerial Imagery/Patrol jobs? TooPlaneCrazy7 Piloting 19 July 16th 04 12:43 AM
GPS Visualizer: new global imagery + new features Adam Schneider Soaring 2 March 18th 04 01:32 PM
