Variometers as audible AOA indicators
Old March 17th 04, 02:52 AM
Jeff Dorwart
Default Variometers as audible AOA indicators
This is basically the same as the operation of the
Cessna Stall warning reed horn. On single engine Cessna
aircraft there is a double reed with an adjusting ring
in the leading edge of the wing. If the pressure gets
too low, i.e. too much lift (low pressure on top of
the leading edge) generated by a high angle of attack
air can be drawn through the reed making sort of a
honking noise. It is adjustable by a movable ring
on the reeds. The reed setup is only about $15.00.
I suspect that instead of in the leading edge a port
could be drilled in the side of the fuselage just above
the leading edge with the same results. I will buy
one and give it a try.jeff
Variometers as audible AOA indicators John Soaring 1 March 17th 04 02:02 AM
Attitude indicators R&A Kyle Instrument Flight Rules 15 December 10th 03 06:56 PM
If airspeed indicators had odometers Wayne Piloting 2 November 14th 03 03:42 AM
