#JWGC August 6th - hopeful for a contest day US Pilots
Old August 6th 17, 12:38 PM posted to rec.aviation.soaring
Default #JWGC August 6th - hopeful for a contest day US Pilots
A cloudy sky postponed the launches for a 2 hour Area task until 13:00 local, then further delayed several times. Launch finally began at 14:29 local. Tracking for today....
http://jwgc.onglide.com/current-day.xml?class=club
Old August 6th 17, 01:20 PM posted to rec.aviation.soaring
and the task has been shortened (is that a word?) to 1.5 hrs. #JWGC US
Old August 6th 17, 03:03 PM posted to rec.aviation.soaring
Per Tony Condon, JP Stewart's crew at about 5pm local:
"Wild day so far here. Daniel and Noah have safely landed and crews are on the way. JP is still up after an impressive save. He did make it into the first turn area. The Germans and one Austrian retreated back to the airfield instead of following the group to a landout. The Germans took a relight but have now returned again. This will make it impossible to have a valid competition day"
A lot of effort today by Team US and the other competitors.
Old August 6th 17, 03:39 PM posted to rec.aviation.soaring
Tony[_5_]
A big line came through right at start time. Good lift along the line but washed everything out behind it. Unfortunately the line did not go to the turn area for Club. They ran it and then glided out into the hole behind. Results were pretty predictable.
The German Team and on Austrian returned to the field and the Germans took another tow about 4:30 PM. They loitered around but it was obvious the day was not going to be valid (especially if they didn't go on task) and they all landed back here.
JP Stewart (BC) is still flying. With luck he'll make it home! Noah and Daniel landed out in nice fields and crews are on the way.
Old August 6th 17, 06:14 PM posted to rec.aviation.soaring
http://www.soaringspot.com/en_gb/jwg...17-08-06/daily
Great stuff, JP
Old August 6th 17, 06:21 PM posted to rec.aviation.soaring
Tony[_5_]
JP finished the task. Too bad we are flying under FAI rules. In the US this would've been a 1000 point day I think.
#JWGC Contest day 3 US Pilots [email protected] Soaring 0 August 5th 17 09:41 AM
JWGC Finally contest day 2 - US Pilots [email protected] Soaring 12 August 5th 17 06:31 AM
JWGC July 31 Contest day cancelled - US Pilots [email protected] Soaring 1 July 31st 17 11:23 PM
JWGC Contest Day 1 -US Pilots [email protected] Soaring 0 July 30th 17 01:10 PM
US Region 3 Contest - August 27 thru September 2nd Tim Hanke Soaring 0 February 23rd 06 09:06 PM
