GlidePlan reviews
Old August 14th 17, 05:18 PM posted to rec.aviation.soaring
Default GlidePlan reviews
Hope there are GlidePlan users who will comment about their experiences with this program. http://www.glideplan.com/ . Worth the price of admission?
Old August 15th 17, 02:44 PM posted to rec.aviation.soaring
Ping
Old August 15th 17, 03:09 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Ping
I have glide plan and like it much. The only flaw I have is my printer ink dries out if I do not print each week. I found GlidePlan well worth the cost.
Old August 15th 17, 06:24 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Ping
I use it fairly often. It is especially useful using the Sectionals and custom charts available at http://www.soaringdata.info/aviation/sectionalTab.html (I donate each time I use it). I use a colour laser printer, and it works well (once I boosted the memory so I could print 2400 dpi vs 600).
Dan
Old August 15th 17, 08:12 PM posted to rec.aviation.soaring
John Godfrey (QT)[_2_]
I use GlidePlan to prepare contest maps. Unfortunately the author abandoned support for it a few years ago - so what you get is what you get. Lynn Alley is still creating current maps that can be used.
Old August 16th 17, 01:19 AM posted to rec.aviation.soaring
And how would one reach Lynn Alley?
Old August 16th 17, 01:45 AM posted to rec.aviation.soaring
Ron Gleason
His web site is http://soaringdata.info/ and the sectionals for Glide Plan can be found here http://soaringdata.info/aviation/sectionalTab.html
There is contact information on the website
Old August 16th 17, 02:10 AM posted to rec.aviation.soaring
Mike C
Glide Plan is a good product that gives a pilot (especially new pilots) useful information for use while planning XC badge flights.
It is worth the price.
Old August 16th 17, 03:17 AM posted to rec.aviation.soaring
Papa3[_2_]
It's probably the easiest way to prepare maps for contests and other "away events" where you want to be able to do flight planning in detail. The three key features for contests: Current sectionals. Easily locating the home point along with distance rings. Quickly putting the turnpoints on the map. Since I only use it infrequently (i.e. at new contest sites or when more than a couple of turnpoints are added/deleted at an existing site, I will say that it's not completely intuitive. Especially the process of loading the map files and getting the print set up correctly seems to be trial-and-error each time I use it (typically one every year or 18 months). I probably ought to just write down the procedures for those steps, but it always seems to be late Friday before heading out at o-dark-thirty for a practice day.
P3
Old August 17th 17, 12:44 AM posted to rec.aviation.soaring
WaltWX[_2_]
On agree with P3's analysis. I use it before flying at a contest site making up colored waypoints for: 1) TPs and waypoints (red for unlandable) 2) marginal landing sites (yellow) 3) airports or sound good landing sites (green). Fiddling with Glideplan to make all this happen is far from intuitive. In fact, it takes me awhile experimenting a bit to make this all work. It doesn't help that I last used the program a year or two before.
But, the software is sound... and works well enough. Lynn Alley makes up sectionals and custom maps that work in Glidplan.
I don't know of any easier way to mark up maps. I used to do it with marker pens drawing circles around waypoints and labeling them. Glideplan is easier. Just don't plan on making up your maps in the last hour before leaving for a contest the next day.
As far as printing it... I just take it to a Kinkos/Fedex down the street; print out 8x10's and use their paper cutters to paste it together... then laminate it with translucent shelf paper.
All told... it probably takes 4-6 hours with all the fiddling and running around.
Walt Rogers WX
P3
Is Glideplan still relevant? Matt Herron Jr. Soaring 18 December 30th 14 06:15 PM
Sectionals for GlidePlan 2KA Soaring 20 June 9th 14 09:43 PM
Glideplan - Matt Herron CJ[_3_] Soaring 1 February 4th 14 12:44 PM
Is GlidePlan still available for download? [email protected] Soaring 1 March 7th 13 02:51 AM
GlidePlan Experience John Seaborn Soaring 5 July 14th 07 06:53 AM
