L/D
Old July 6th 04, 03:31 AM
DJFawcett26
Default L/D
Hello All,
Since this is about the most resouceful group I know, I though somebody may be
able to help. I have been trying to find the supersonic L/D of the B-1A or B
and the SR-71. Does anybody have any information concerning either. I realize
that the L/D is mach dependent, but I can not fine anything at any mach number.
I am doing a comparative analysis on a supersonic configuration, and the info
would be most helpful.
Thanks in advance for any help
Best Regards,
Dave
Old July 6th 04, 05:30 AM
DJFawcett26
Supersonic L/D is very complex, as angle of attack affects drag
drastically. You would almost need a complete set of aerodynamic tables
which show normal force and axial force coefficients as a function of
both Mach no. and alpha. I am sorry, but there is really no simple
answer.
I realize there is no simple answer, I was trying to elude to that point when I
first asked the question. Of course alpha effects drag which effects L/D, and
on, and on, we go. I am not asking for a detailed engineering exercise. All I
am really asking "is there any L/D published data that may be found". This is
a very, very, very top level analysis, not a detailed engineering exercise.
You might say extremely parametric is nature. All configurations have an
optimum L/D (max) for given mach point (taking into account everything you
describe and more), and that is what one usually finds in the publications.
Everybody shows there best.
I do appreciate your response, but all I am looking for is something ( that is
somewhat reasonable) to turn into a point on a chart - LOL.
Thanks again
Dave
Old July 6th 04, 04:41 PM
Richard Isakson
Dave,
I don't know if this will help but when you need data sometimes anything
will do.
"Supersonic and Subsonic Airplane Design", Gerald Corning, 1970, lists the
projected cruise L/D of the Boeing SST (2707-300) as 7.35 at mach 2.7 and
60,000 feet. Boeing was quite proud of the -300 until they started doing
powered wind tunnel tests. It turned out that at cruise the engine exhaust
hit the tail and would have burnt it off. Faced with pressure from Congress
and the need for yet another complete airplane redesign, Boeing killed the
program. When it comes to an American SST, "that's the rest of the story".
I'll see if I have anything else around here but you might try a search of
"Aviation Week" for that period. A long time ago I found some of my work
there before I had even finished with it.
Rich
Old July 6th 04, 05:18 PM
DJFawcett26
Appreciate the help guys! You're right Rich, at a point, anything with do.
And Stealth Pilot, thanks very much!
