Libelle Gap Sealing
Old April 7th 04, 03:28 PM
Owain Walters
Default Libelle Gap Sealing
Hi,
Has anyone bought 'Complete Control Gap Kit' from Steifeneder?
Are the supplies sufficient to seal both the upper
and lower gaps on the ailerons and elevator? Are the
instructions in English?
Also, does anyone have any informed ideas about using
the 'Combi' mylar (the mylar with the zig-zag leading
edge) vs. the curved mylar on a Standard Libelle? Is
there any benefit?
Any info would be much appreciated.
Owain
Old April 7th 04, 06:38 PM
Sf760
I put a Streifeneder seal kit on a Std Libelle, there was enough to do both
sides of all the control surfaces, and the instructions were easy enough to
make sense of if you studied them for a few minutes.
Si
Old April 8th 04, 12:35 AM
Nick Gilbert
After years of extensive & thorough testing, I have found the combi tape to
be MUCH sexier.
Nick.
"Sf760" wrote in message
both
to
Si
Old April 8th 04, 01:22 AM
JJ Sinclair
there any benefit?
I would use the combo-mylar on only the rudder. Not necessary on elevator or
ailerons and the zig-zag in these areas can produce unwanted control actions. I
did the above on my H-301 and she is the sweetest libelle in the country, isn't
it Cam?
JJ Sinclair
Old April 11th 04, 07:13 PM
Wood Hawk
JJs H-301 -
Seals work great! Flew N18L yesterday out of Mountain Valley - at 6:00
pm I was really ready to land, but was at 8,000 msl and still climbing
300 fpm. While derigging, someone asked me if this was "one of those
new manufacture Glasflugel gliders" that Tim Mara imports. A real
tribute to JJ's handiwork!
Aside: An H-301 Libelle is what got JJ out of his Duster, and this
H-301 is the reason my Duster is (reluctantly) for sale.
http://www.wingsandwheels.com/want-ads7.htm
Cam
(JJ Sinclair) wrote in message ...
there any benefit?
it Cam?
JJ Sinclair
H201b Standard Libelle for low time pilot Miguel Lavalle Soaring 2 October 6th 10 10:43 PM
64 M20c Avionics Cover Sealing? BellSouth.net News Owning 2 August 23rd 04 03:42 AM
Turbulators on Club-Libelle Christoph Barniske Soaring 9 January 22nd 04 05:50 PM
Libelle balsa to foam switch tango4 Soaring 1 November 14th 03 03:13 AM
sealing cork float against gasoline - how to... jt Home Built 13 July 18th 03 10:51 PM
