Oudie Supplemental Power Pack
Old September 26th 17, 01:31 AM posted to rec.aviation.soaring
Roy B.
Default Oudie Supplemental Power Pack
Friends:
I am looking for a supplemental power pack that is easily rechargeable, reasonably compact, and will run my Oudie for 5+ hours on a single charge. Any suggestions?
ROY
Old September 26th 17, 01:45 AM posted to rec.aviation.soaring
Craig Funston
On Monday, September 25, 2017 at 5:31:19 PM UTC-7, Roy B. wrote:
Friends:
ROY
https://www.amazon.com/Jackery-Premi...FNV9V9NYGRYKKQ
Less than $30 from Amazon. I've had mine for a year and have been very satisfied with it.
Craig
Old September 26th 17, 02:59 AM posted to rec.aviation.soaring
On Monday, September 25, 2017 at 6:31:19 PM UTC-6, Roy B. wrote:
Friends:
ROY
Anything over a 3,000 mAh battery will run it for the longest of flights. The one Craig suggested is perfect. Will last multiple flights probably.
Old September 26th 17, 08:23 AM posted to rec.aviation.soaring
Michael Tinkler
There are many of these on eBay, but with the addition of solar charging.
Do a search on solar power bankðŸ‘
I fixed mine on top of the instrument panel using Velcro.
Excellent for your 5 hour flight.
Old September 26th 17, 08:24 AM posted to rec.aviation.soaring
Michael Tinkler
Michael Tinkler
Old September 26th 17, 08:43 AM posted to rec.aviation.soaring
Jim White[_3_]
Add a ferrite to the power cable if it causes radio interference. Most do.
Old September 26th 17, 08:55 AM posted to rec.aviation.soaring
Michael Tinkler
Old September 26th 17, 04:57 PM posted to rec.aviation.soaring
If it is not a constant load then some of the "external power packs" may shut themselves off when they see no load. I don't know about the Oudie, but I've had such problems with other devices. Those battery packs that you have to start with a button push (the vast majority) are the ones to avoid. There are a few models that either have an on/off slide switch, or sense the load and automatically turn themselves on.
Old September 26th 17, 08:37 PM posted to rec.aviation.soaring
Dan Marotta
Think I'm gonna buy me one of THESE
https://www.walmart.com/ip/300000mAh-Dual-USB-Portable-Solar-Battery-Charger-Solar-Power-Bank/577223227?wmlspartner=wlpa&selectedSellerId=11232& adid=22222222227082152808&wmlspartner=wmtlabs&wl0= &wl1=g&wl2=c&wl3=196724236981&wl4=pla-314508929942&wl5=9030458&wl6=&wl7=&wl8=&wl9=pla&wl 10=117089434&wl11=online&wl12=577223227&wl13=&veh= sem.
When it doesn't deliver the promised 300 amp hours (300000 mAh), I'll
sue WalMart and then buy me a new ASH-31 mi.
Dan, 5J
Oudie starved for power Matt Herron Jr. Soaring 11 February 21st 17 06:34 AM
Power pack for camping? LincTex General Aviation 2 June 26th 06 12:40 PM
Power pack for camping? LincTex General Aviation 0 May 31st 06 11:09 PM
Supplemental O2 and children Peter R. Piloting 23 April 18th 06 01:47 PM
Power pack for camping? Paul Tomblin General Aviation 6 February 27th 06 02:17 PM
