Cup holder
Old October 19th 17, 09:38 PM posted to rec.aviation.soaring
Default Cup holder
Has anyone installer a cup holder on their glider? Pictures?
Old October 19th 17, 09:49 PM posted to rec.aviation.soaring
Darryl Ramm
Default Cup holder
The luggage shelf on my glider holds a latte while prepping the glider on the ground. So does the rear of the trailer.
You really mean while flying? How much fun do you want other pilots to make of you?
What you should be looking at, assuming you want to fly cross country, is where to place Camelbak or similar hydration packs. How to route the drinking tubes, retain them so you don't sit on them, etc.
Old October 19th 17, 10:23 PM posted to rec.aviation.soaring
Default Cup holder
I have a camel back. What if I also want to have a thermos with some ice and pepsi to enjoy a sandwich? ...
Old October 19th 17, 10:28 PM posted to rec.aviation.soaring
Papa3[_2_]
Default Cup holder
This guy probably had a cup holder. https://youtu.be/V9pvG_ZSnCc
Old October 19th 17, 10:36 PM posted to rec.aviation.soaring
Darryl Ramm
Default Cup holder
Get an insulated Camelbak, stuffed behind a seat out of the sun they hold ice for hours. Fill 3/4 full with ice cubes and then top with water or maybe a sports drink (if so wash out immediately after flight). Carry a lot of fluids, plan for worse case landout. Put extra water in your crew car or trailer.
Worry about what is important. If you are worrying about cup holders I am concerned what else might be going astray. Especially if you have little XC experience find a good local mentor who can help you set up your ship for XC.
Besides basic flyability of the glider the next thing to get set up properly is a perfectly working trailer and then a pee tube.
A thermos can smack you in the head in severe turbulence or roll around and potentially block the rudders. You just don’t have space for a cup holder.
Old October 20th 17, 12:01 AM posted to rec.aviation.soaring
Dan Marotta
Default Cup holder
My sammich goes great with water.Â* In the summer my camel back is
refrigerated, sometimes iced.Â* In the winter, it's room temperature.
Dan, 5J
Old October 21st 17, 08:49 PM posted to rec.aviation.soaring
jfitch
Default Cup holder
If you are sensitive to taste, you may find water from a Camelback tastes like a chemical factory. There are many competitors using PE bags that don't have that taste. Platypus is one such.
Old October 22nd 17, 12:17 AM posted to rec.aviation.soaring
Default Cup holder
1/3rd strength gatorade take care of the past and give you some electrolytes and some sugar that you need.
Kevin
92
Old October 22nd 17, 08:12 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Default Cup holder
Here's a picture, works great.
http://sc02.alicdn.com/kf/HTB1sgi3KF...Holder-Hat.jpg
Old October 22nd 17, 01:27 PM posted to rec.aviation.soaring
JS[_5_]
Default Cup holder
I installed this cup holder a couple of decades ago.
May not work with your present system.
http://www.softpedia.com/get/Others/...p-Holder.shtml
Cup holder [email protected] Soaring 20 October 30th 17 10:51 PM
Need pictures of Komet Trailer Elevator Holder Scott Alexander[_2_] Soaring 0 July 25th 12 08:50 PM
taller battery holder/clips for Ventus 2? Frank[_12_] Soaring 16 October 9th 10 04:57 AM
L13A Type certificate holder Bruce Soaring 7 August 19th 10 07:01 PM
Wave Alert and record holder caught cheating? bumper Soaring 2 March 15th 09 09:23 AM
