sacrificial aluminum
Old July 12th 04, 04:07 PM
Rob
Default sacrificial aluminum
Hi Y'all,
I am in the process of assembling my workshop prior to ordering a
quickbuild RV kit.
I can see that some priming is necessary, even with a quick-build kit.
I own an airless sprayer that might be suitable for primer application
on small parts. The sprayer was mainly used to spray bottom-paint on my
sailboat. The paint is teflon based, mixed with powdered copper.
Of course I cleaned the sprayer according to the instructions, but the
reservoir seems stained, and I wouldn't be surprised if a small amount of
copper was still in the inner works of the sprayer.
My question for the chemically inclined among you is this...Would copper
act as the sacrificial metal or would the aluminum I am trying to protect
sacrifice itself for the copper?
kleindoc
Old July 12th 04, 09:45 PM
Bryanmaxmartin1
Aluminum has a lower electronegativity (greater tendency to oxidize) than
copper, so it will sacrifice itself for the copper.
Date: 7/12/2004 11:07 AM Eastern Daylight Time
Message-id:
kleindoc
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
A Source for Aluminum Ron Wanttaja Home Built 4 October 11th 03 01:38 AM
