Pawnee Tost 337 completed after the fall of 2003?
Old May 13th 04, 02:48 AM
Stewart Kissel
Default Pawnee Tost 337 completed after the fall of 2003?
CUT-
It appears the FAA is going to stop field approvals
for tow hooks.
Their latest statement,' there must be an STC or be
listed in the Type
Certification Data Sheet for the aircraft'
CUT-
Our mechanic has just encountered this situation, specifically
a US registered Pawnee that has not towed before.
He has been told he needs a STC. Has anyone come up
with a work-around for this?
Old May 13th 04, 03:04 AM
Bob Kuykendall
Earlier, Stewart Kissel wrote:
...Our mechanic has just encountered this
situation, specifically a US registered Pawnee
that has not towed before. He has been told
he needs a STC. Has anyone come up with
Air Sailing has recently managed to certify their Pawnee
for towing, and indeed it wasn't easy. You might contact
Jim Hayes of Air Sailing for some guidance.
Bob K.
Old May 13th 04, 03:43 AM
Stewart Kissel
Bob K.
Thanks for the HU Bob, I sent an email to Jim and Rick
W. to glean information. I see from reading their
newsletter it took them 5 months to get through the
approval process. I suppose I could make some snide
comment at this point about our tax dollars at work,
but that would be counter-productive
Old May 13th 04, 05:39 PM
Tim Mara
not true...........at least it is not an official FAA policy.....
FSDO's can and most still will do field approvals......however, some FSDO's
won't, that's a local decision.....if your local FSDO won't you can check
with other FSDO's nearby who might.the Local FSDO won't necessarily like
this and then might agree to do the approval.....use some diplomacy and you
should get cooperation....
tim
"Stewart Kissel" wrote in
message ...
CUT-
for tow hooks.
listed in the Type
CUT-
Old May 13th 04, 06:18 PM
Roy Bourgeois
I am currently working this problem in Massachusetts and have some =
thoughts to share with anyone doing the same. If the aircraft has never =
towed before - I strongly recomend starting out with the standard =
Schweizer hook and not the Tost unit. This is essential if it's a =
Restricted Pawnee. The Tost unit requires the FAA ASI (the guy who OKs =
the 337) to contact "FAA Engineering" - and that creates a host of =
problems that you don't want to complicate the change in use.=20
Pleae feel free to contact me off net.
roy
Old May 13th 04, 09:16 PM
Stewart Kissel
Yep, we got a Restricted Pawnee that has never towed.
And I talked the owner into the safer and more expensive
Tost unit. And the FSDO says no field approval, period.
I got some good information from the AirSailing group
who have had two Pawneess approved recently, and waiting
to hear back from Stephen Northcraft in regards to
the SSA liaison to the FAA on this subject.
and have some =
the standard =
if it's a =
the 337) to contact 'FAA Engineering' - and that creates
a host of =
in use.=20
roy
Old May 13th 04, 09:30 PM
Stewart Kissel
Roy B.-
I sent you a couple of emails using my hotmail account,
you might check your spam filter if they don't show
up in your inbox.
and have some =
the standard =
if it's a =
a host of =
in use.=20
roy
Old May 14th 04, 05:54 AM
Bob C
Very simple. Write your congressman. Be tactful,
but explain that there are hundreds of Pawnees around
the country safely towing gliders. Also explain that
the FAA is hindering commerce. It's much easier to
start at the top than to try to slug your way up the
chain of command. Just my $.02 worth, but it does
work.
and have some =
the standard =
if it's a =
a host of =
in use.=20
roy
Old May 14th 04, 09:59 PM
Jim Phoenix
Bob C wrote in message ...
I would bet good money it's much faster just to hire a structures DER
and get an 8110-3 form that FAA approves the data for the
installation. Then pay your local A&P to install it and then pay your
local IA to inspect the installation and approve the 337 and it's
done.
No need to bother the local FSDO at all.
FAA approved (upside-down, right side up, Tost, Schweizer,
whatever)for the cost of a DER, A&P and IA. If you want only to save
money and have lots of time to wait while new policy is written and
approved, maybe you could call your congressman.
Also, a DER-approved 8110-3 should pave the way for approval for our
friends across the various ponds that have bi-laterals with the US
FAA, and there are many of those.
DER list is available on the web:
http://www.faa.gov/certification/air...RDirectory.pdf
Lots of other guidance and policy is on the web as well, the 8300.10,
Volume 1 has a chart that shows exactly what alterations the local
FSDO can approve and what they cannot. STC process sounds exciting,
but is merely time-consuming and expensive, and eventually profitable
if you sell your STC'd (e.g. Pawnee mirror installation) to other
clubs or operators.
Old May 15th 04, 01:00 AM
Stewart Kissel
Update-
Jim Hays was a huge help to us, he is providing the
documents needed to take a Restricted Pawnee back to
Standard. In theory once this has occured, some FSDO's
may approve the TOST 337. There is a little more to
it then that, but that is the basic concept. Jim has
put a huge amount of time in pioneering this road.
Baby Bush will be Closing Airports in California to VFR Flight Again Larry Dighera Piloting 119 March 13th 04 03:56 AM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 13th 03 12:01 AM
15 Oct 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 October 15th 03 10:21 PM
18 Sep 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 0 September 19th 03 04:47 AM
04 Sep 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 0 September 5th 03 03:57 AM
