All,
Advice needed My canopy frame and caopy are beginning to disbond. Need to know what to use to glu them back together. Current thoughts a epoxy and flox, poluerthane cement, acrylic cement (for plexiglas crack repair), and adhesive sealant like 3M 5200. Ideas please. Nolaminar?, JJ? Thanks!!! -- Pete Reinhart Austin, Texas |
Yo Pete,
The big problem is your canopy wasn't sanded enough before it was glued on last time. I mask it off and then sand the hell out of the 20 mm area where the epoxy glue and cotton flox will be applied. I sand with 40 grit till all the shiny is gone and then blow it off and glue her on. A few wood screws may be necessary to keep it in place, but I remove them before the epoxy gets rock hard. If it is that loose, can you take it completely off and start over? If not, you need to get some ruffage up there in between the glass and the frame. If that's not possible, you can drill some holes and let the epoxy ooze out through these holes. That might be enough to keep her down. Mask everything off, its much easier than removing fingerprints etched in epoxy. JJ Sinclair |
Glue question | [email protected] | Owning | 1 | December 6th 04 03:25 PM |
Glue for wing step grippy thingies | Steven Barnes | Owning | 6 | November 28th 04 09:56 PM |
Drywall Gussets | Veeduber | Home Built | 5 | October 27th 03 09:03 PM |
Qn: Casein Glue recognition | Vassilios Mazis | Soaring | 0 | August 20th 03 10:00 PM |
Glue | Adair | Home Built | 3 | July 18th 03 10:15 PM |
