Glider cockpit size
Old November 25th 17, 03:26 AM posted to rec.aviation.soaring
Steve Muhli
Default Glider cockpit size
Hi, New to this forum, thought I 'd pose a question..... I have a glider
rating
from years ago, I was wondering if anyone can suggest a list of gliders
that
are more "roomy" inside since I am 6'4" . I am planning on going to the
SSA
convention in Reno in 2018 to check out the new stuff....I've sat in an SZD
55, that's about it.... Thanks
Old November 25th 17, 04:03 AM posted to rec.aviation.soaring
Michael Opitz
glide
rating
glider
that
to th
SSA
an SZ
Discus-2b and Ventus-2b should be comfortable up to ~6'5" with
a normal chute. Genesis is also roomy, but not many around or for
sale. A lot depends on your wallet, experience level, and what you
are trying to accomplish. Most of the older gliders were not built
with a 6'4" pilot in mind. The Discus-2b and Ventus-2b fuselages
were the first where Schempp-Hirth said that they wanted to design
a cockpit which almost anyone could get into comfortably. Other
manufacturers have gradually over time enlarged the insides of
their cockpits in order for taller people to fit as well.
Most glider seat belt attachment fittings are the limiting factors
for weight in the seat. For most, the max weight is 242 Lbs or
110 Kg.
You will probably get a bunch of other suggestions from this forum.
Good luck...
RO
Old November 25th 17, 09:22 AM posted to rec.aviation.soaring
Craig Lowrie
Try an HPH Shark... It probably has the most roomy cockpit out there...
6'4" will fit ok... Craig
glide
rating
glider
that
to th
SSA
an SZ
110 Kg.
Good luck...
RO
Old November 25th 17, 10:28 AM posted to rec.aviation.soaring
Bruce Hoult
glide
rating
glider
that
to th
SSA
an SZ
110 Kg.
To be specific, the seal belt attachments are designed and certified to not fail in a 40 G deceleration with a 110 kg person.
If you weigh 120 kg (265 lb) then try to keep your crashes down to 36.7 G.
No one ever mentions: the back seats of two seat gliders are often very roomy, at least side to side and maybe for torso length. They are not necessarily so great for legroom.
Old November 25th 17, 01:18 PM posted to rec.aviation.soaring
Michael Opitz
110 Kg.
not
36.7 G.
In the USA, insurance gets to be a problem in that area. If one
intentionally flies the aircraft over a certain placard/handbook limit,
and has an accident, then this becomes a way for the insurance
company to deny payments.
RO
Old November 25th 17, 01:42 PM posted to rec.aviation.soaring
Bruce Hoult
110 Kg.
not
36.7 G.
Legally, only if it's the cause of the accident.
Old November 25th 17, 01:56 PM posted to rec.aviation.soaring
Tim Newport-Peace[_4_]
110 Kg.
not
36.7 G.
A bit surprised that no-one has mentioned CG Limits or AUW.
Delibrately going outside either of these limits could (in UK/European Law
anyway) be 'endangering an aircraft', for which you could be prosecuted,
regardless of any accident.
Lots of Wriggle-Room for an insurer here.
Old November 25th 17, 03:05 PM posted to rec.aviation.soaring
OHM Ω http://aviation.derosaweb.net
I think that this subject has come up a few times on RAS so it may pay to search the archives. Here is one https://groups.google.com/forum/#!searchin/rec.aviation.soaring/tall$20pilot%7Csort:date/rec.aviation.soaring/ZD-7HqoBYTQ/l0SLOYEACAAJ.
The one glider family that I know fits taller pilots is the DG line. Several DG's are for sale right now on the http://glidersource.com web site. Also, I have a tall pilot friend that fits comfortably in his Schleicher ASW-24 with the seat back removed, which I assume means that other ASW, ASH, etc, gliders would fit the bill.
Best of luck. Get back in the air!
John OHM Ω
Old November 25th 17, 03:46 PM posted to rec.aviation.soaring
Michael Opitz
other ASW, ASH,
I am 6'2" and had one of the first (SN #8?) ASW-24's. I was so
crammed in (with the seat back removed) that I was afraid to make
an off-field landing in fear of putting my head through the canopy.
I complained to Gerhard Waibel about this, so he told me that in the
newer ones he had moved the cockpit bulkhead back about 4 cm, and
this would fix the problem. He told me that my old -24 could not be
modified, so I should just buy a new one - which I did. (That was
around ~1990) The new one was somewhat better, but I was still
uncomfortable even with the seat back removed. I understand that
Chip Bearden got a much later model which had the cockpit modified
once again, so that he can fit comfortably. Bottom line = Don't
assume all ASW-24 cockpits are the same size. They aren't. I have
heard that later ASW-ASG models have been improved in this regard.
Again, the newer ships will probably fit you better.
Try it on before you buy it.....
RO
Old November 25th 17, 04:38 PM posted to rec.aviation.soaring
jfitch
other ASW, ASH,
RO
I am 6'4" and don't fit in an ASW27. But I fit fine in an ASH26, which has a cockpit about 4" longer. I also fit in an JS1, since the fuselage is an exact copy of the ASH26. An ASH31 shares the fuselage with the 26, so I fit in that as well. I have yet to sit in a Ventus that I could fit comfortably in but there are many variants and I haven't sat in all of them. I have yet to sit in a two seat that really had enough legroom front or rear (Grob 103, ASK21, DuoDiscus, ASW32 among them).
Dg600 cockpit size [email protected] Soaring 2 September 21st 16 11:09 PM
Discus 2a cockpit size EdByars Soaring 1 March 18th 10 03:37 AM
Discus 2a cockpit size Stephen[_3_] Soaring 7 March 17th 10 05:57 PM
Cockpit size of Libelle? Kevin Morris Soaring 4 July 15th 04 11:32 PM
