iPAQ h5455 Blues - Help!
Old May 18th 04, 09:44 PM
Paul Remde
Default iPAQ h5455 Blues - Help!
Hi Everyone,
I have a Glide Navigator II customer with an iPAQ h5455 and neither of us
can get it work with Glide Navigator II - or any other GPS program. I've
tried using a GPS test utility called Crux_View that allows me to test each
serial port one at a time. I'm connected to a GPS-NAV but can't see the GPS
data.
I'm writing to ask if any of you (technical bunch that you are) have had
success with an iPAQ h5455 and a GPS connected through the RS-232 serial
data port on the bottom of the unit. Please let me know if you have.
Also, I'm wondering if perhaps the problem is caused by a setting that is
set incorrectly.
I'm usually very good at getting Pocket PCs to work. I've played with
dozens of them over the last few years. But I'm hoping that someone in this
group will have run into this issue before and have a suggestion.
Glide Navigator can't find GPS data so it eventually quits trying to find
the GPS and runs in simulator mode. That makes sense since the Crux_View
utility can't see GPS data on comm ports 1 to 9.
I've tried doing a soft reset.
The BlueTooth Radio is turned off. Wireless Ethernet is turned off.
Any suggestions?
Paul Remde
Cumulus Soaring Supplies
http://www.cumulus-soaring.com
Old May 18th 04, 09:52 PM
Paul Remde
Hi,
I forgot to mention that my iPAQ 3970 works fine with the GPS-NAV and GN II
with both the iPAQ cradles (his and mine) I'm using for testing.
Paul Remde
"Paul Remde" wrote in message
news:6Buqc.31424$6f5.2975126@attbi_s54...
Hi Everyone,
each
GPS
data.
set incorrectly.
this
Any suggestions?
Paul Remde
Old May 19th 04, 12:06 AM
Jeff Dorwart
Paul, Have you considered trying a bluetooth gps (if
you have one available?)At 21:06 18 May 2004, Paul Remde wrote:Hi,I forgot to mention that my iPAQ 3970 works fine with
the GPS-NAV and GN IIwith both the iPAQ cradles (his and mine) I'm using
for testing.Paul Remde'Paul Remde' wrote in messagenews:6Buqc.31424$6f5.2975126@attbi_s54... Hi Everyone, I have a Glide Navigator II customer with an iPAQ
h5455 and neither of us can get it work with Glide Navigator II - or any other
GPS program. I've tried using a GPS test utility called Crux_View that
allows me to testeach serial port one at a time. I'm connected to a GPS-NAV
but can't see theGPS data. I'm writing to ask if any of you (technical bunch
that you are) have had success with an iPAQ h5455 and a GPS connected through
the RS-232 serial data port on the bottom of the unit. Please let me
know if you have. Also, I'm wondering if perhaps the problem is caused
by a setting that is set incorrectly. I'm usually very good at getting Pocket PCs to work.
I've played with dozens of them over the last few years. But I'm hoping
that someone inthis group will have run into this issue before and have
a suggestion. Glide Navigator can't find GPS data so it eventually
quits trying to find the GPS and runs in simulator mode. That makes sense
since the Crux_View utility can't see GPS data on comm ports 1 to 9. I've tried doing a soft reset. The BlueTooth Radio is turned off. Wireless Ethernet
is turned off. Any suggestions? Thanks, Paul Remde Cumulus Soaring Supplies http://www.cumulus-soaring.com
iPaq and LX5000 connectivity question (hardware?) Ted Wagner Soaring 1 April 22nd 04 09:29 PM
Commercial - iPAQ Cradle Changes Paul Remde Soaring 0 April 9th 04 03:29 PM
iPaq wiring, cradles and mounts for gliders - Ideas?? Jim Kelly Soaring 12 December 4th 03 11:45 PM
iPAQ h2210/h2215 Review Paul Remde Soaring 0 September 3rd 03 03:45 AM
iPaq screen viewability Raphael Warshaw Soaring 7 July 27th 03 06:02 PM
