IMI versus MM Fab Riggers
Old December 5th 17, 02:33 AM posted to rec.aviation.soaring
Default IMI versus MM Fab Riggers
Looking for a rigger to use on ASW 20. Have seen both brands in common use. The IMI seems to cost less. Would be interested in discussion of pros and cons of the two different makes.
Tom A
Old December 5th 17, 01:32 PM posted to rec.aviation.soaring
Ron Gleason
Tom A
Can only speak about the MM Rigger as that is what I use, have only seen the IMI from afar. The MM Rigger is well built has been constantly tweaked over the years by the original designer, Steve K. I have known Mark Mocho from MM for a few decades starting during the HG days. He makes great products and provides awesome support and I am sure he will continue with the MM Rigger.
American designed, American made, American supported. Does not get any better and you cannot go wrong with the MM Rigger.
Old December 5th 17, 03:21 PM posted to rec.aviation.soaring
AS
Tom A
I have not seen or used a MM-self rigger but I have used two IMI products so far.
Currently, I am using a IMI-self rigger for my Calif and it works great. I can put the outer wing panels on by myself (same length than a 'normal' 15m ship). The gas strut has become a bit weak but I can replace it w/o special tools. What I really like is the fact that the entire rigger breaks down into several pieces w/o the need for tools and can be stored flat in the trailer. Well designed and built.
Uli
'AS'
Old December 5th 17, 03:22 PM posted to rec.aviation.soaring
Steve invented the 3 wheeler which won't flip over in most cases. With a 2 wheeler, a problem arises during disassembly when wing is lifted off the tool to shove it into the trailer............the out-rigger wheels are retracted and you must remember to extend them or the stand will fall over as you lift the wing, prior to shoving it into the trailer. If the tool falls over it will most likely strike your fuselage! Ask me how I know this to be true!
The 3 wheeler with lateral adjustment does have a hidden flaw. Steve's original design didn't have lateral adjustment and the vertical post was welded in a stable location. The lateral modification alllowes the vertical post to move well past the "stable" location of the original design. If the operator forgets to lock the lateral adjustment, a slight wind can/will allow the rig to move all the way to the "unstable" end position and the wing and tool can flip over.........ask me how I know this?
All in all, I believe the 3 wheeler to be the better design, but both models demand your un-divided attention!
Hope this helps,
JJ
Old December 5th 17, 05:32 PM posted to rec.aviation.soaring
JS[_5_]
I've used the Cobra manual, Cobra electric, Udo Rumpf with and without lateral adjustment, Steve Koerner with and without lateral adjustment, an old style Mark Mocho rigger, and a couple of home made ones.
Will use an IMI electric in a week.
Not a fan of the gas strut versions of any of them. Thought the one Udo made for my 26E was the best.
The training wheels that you spin out of the way can be a problem, but so can the tricycle gear if the glider has a lot of dihedral.
ASW20 will be easy to rig. Anything with spar end spiggots (mostly old but plenty are still made, like New Ventus and JS3) are more difficult.
With any rigger, get flat free wheels or make the wheels flat free. Some older Koerner ones had low capacity wheels that fail, believe MM has fixed that.
Hope this helps,
JJ
Old December 5th 17, 08:02 PM posted to rec.aviation.soaring
chuck[_3_]
Agree with JS on the Udo rig. Any idea where he got his crank mechanism?
Chuck
Old December 5th 17, 10:21 PM posted to rec.aviation.soaring
Jock Proudfoot
mechanism?
Chuck
Mercedes car jack from the junk yard for the first few. Later he bought
them new from a car dealer.
Old December 6th 17, 01:48 AM posted to rec.aviation.soaring
Dave Nadler
I've owned Udo, Cobra, and lately IMI riggers. Also used several others.
IMI is the best I've used:
- Constructed with large aluminum square tubes - string and light
- Nice big pneumatic wells roll easy over soft ground
- Beautifully made.
With a string gauge (not shown in video) I solo assemble my ArcusM quickly
and easily. I modified a non-electric unit to electric; probably you've seen:
https://www.youtube.com/watch?v=JEUQLSgUpoY
No more strained back!
Hope that helps,
Best Regards, Dave
Old December 6th 17, 02:37 PM posted to rec.aviation.soaring
- Beautifully made.
Hope that helps,
Best Regards, Dave
Or, you can build your own "Power Rigger" with dual remote controlled axes as I did for my '29. This is my second iteration, the first had only the vertical motion. Yes, I could be a little more verbal in my explanations - be like Dave.
https://www.youtube.com/watch?v=jnmaUsPtvSI
Herb
Old December 6th 17, 07:58 PM posted to rec.aviation.soaring
Beautiful !
can you send me a link to more pictures ?
dan at crosscountrybox dot com
Dan
- Beautifully made.
Hope that helps,
Best Regards, Dave
Herb
LPV versus LNAV/VNAV versus LNAV+V Wyatt Emmerich[_2_] Instrument Flight Rules 6 December 17th 07 01:38 AM
F-8 versus F-4 Doug \Woody\ and Erin Beal Naval Aviation 43 October 12th 05 08:49 PM
F-8 versus F-100 Doug \Woody\ and Erin Beal Naval Aviation 6 May 16th 05 10:01 PM
"zero" versus "oscar" versus "sierra" Ron Garret Piloting 30 December 20th 04 08:49 AM
Self-Riggers and disassembly of wings Stewart Kissel Soaring 11 August 19th 03 02:56 PM
