Beeping Thing
Old February 14th 05, 11:40 PM
Slick
Default Beeping Thing
I can't figure out what this beeping thing was that I encountered the other
day while flying a 172 from our club. I'm a fresh private and I took my
parents to Mansfield airport for Sunday morning breakfast. When we left on
runway 14 This beeping thing came on. I think it's a DME. I've seen one in
use before, but I couldn't figure it out and it scared my mother half to
death, (She thought it was a sound that meant the engine was about to die).
How do I turn it off? This plane is equipped with the standard NAV/COM, it
has an ADF and Garmin GPS with moving map. I tried Flipping all kinds of
switches to turn it off and I couldn't figure it out. I knew it was a marker
of sorts, so I knew it would go away, I just hoped it would go away fast to
ease everyone anxiety. Any tips on how to turn it off?
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
Old February 14th 05, 11:50 PM
Stephen McNaught
Slick,
You should be able to find your specifics in the POH for the airplane. If
it's the marker beacon that you're hearing, depending on the audio panel in
the airplane, there is probably a mute button for it, or you could
"deselect" the MKR button.
- Steve
"Slick" wrote in message ...
other
die).
marker
to
News==----
Newsgroups
Old February 14th 05, 11:58 PM
Mike W.
Marker beacon, used for instrument approaches. Usually at the top of the
radio stack, may be incorporated into the audio panel. Look for blue, orange
and white lights. Should be a volume knob/power switch to turn it down/off
if it is a seperate unit. If it's a part of the audio panel, you will have
to find the appropriate switch (do it while on the ground, before you start
up) to turn the audio off. Either way, it's nothing to worry about.
BTW, are you talking about MFD?
other
die).
marker
to
News==----
Newsgroups
Old February 15th 05, 12:28 AM
Robert M. Gary
Does your field have an ILS approach for instrument landings? If so its
probably the marker beacons. They can sound like a really nasty alarm
going off when you fly over them. Either you have "marker" turned on on
your audio panel or you are flying a typically rental 172 and the
radios don't do exactely as they are told. We have a Cherokee I teach
in that requires you to dial 1 MHz more than the freq (KX-170B). So for
118.32 you have to dial 119.32. I'd never allow such things in my
Mooney but you have to break even in the renal market.
-Robert, CFI
Old February 15th 05, 12:45 AM
Stephen McNaught
If (s)he's refering to K1B9, Mansfield, Mass., then it does not have an
ILS. Don't know when the beeping was heard, but there are other airports in
the area that do have ILS approaches.
- Steve
Old February 15th 05, 12:52 AM
Stephen McNaught
I see that the Mansfield airport in Ohio (KMFD) does have an ILS 32
approach.
- Steve
"Stephen McNaught" wrote in message
in
- Steve
Old February 18th 05, 04:47 AM
JF
There is no such identifier as K1B9. The Mansfield, Mass airport is 1B9. ICAO
identifiers do not have numbers in them.
Old February 15th 05, 01:29 AM
-Robert, CFI
If I'm going sell my kidneys I'd better do a whole lot better than just
break even.
a.
Old February 15th 05, 01:55 AM
Mike W.
-Robert, CFI
break even.
a.
HHAAaaa HHaaaaaa!
Old February 15th 05, 03:38 AM
BTIZ
-Robert, CFI
Write it up.. and don't use the airplane?? maybe when the "owner" realizes
he's loosing revenue for a bad radio.. he'll get it fixed... I would never
take an airplane IFR like that.. I hope the bad one is "radio #2".. We had a
repeat problem like that with a radio here in the Arrow.. After I refused to
take the rental for IFR refresher.. because you could not tell what
frequency you were on.. the FBO swapped out the radio. Had the same problem
with "LEDs" failing.. cant tell Freq or read the DME.. can't fly one IFR
approach around here without DME.. so I refused the rental... He put in an
KNS80.
BT
wanna do a good thing? Sporkman Home Built 1 June 20th 04 06:43 PM
150HP Super Yankee FS I forgot to post one last thing! Bill Berle Home Built 0 October 20th 03 09:46 AM
The Piper Cubs That Weren't Veeduber Home Built 5 August 28th 03 04:38 AM
Is a static port a precision thing? Larry Smith Home Built 8 August 12th 03 10:26 PM
SUV thing Fastglasair Home Built 4 July 12th 03 05:32 AM
