Mobile Aviation Antenna for RV
Old December 6th 17, 03:20 PM posted to rec.aviation.soaring
Don Grillo[_2_]
Default Mobile Aviation Antenna for RV
I want to purchase an antenna to mount on the top of the ladder on my RV. I've been looking at the RAMI AV-3 and AV-7 antenna's. I will have to fabricate some sort of rotating base so that I can swing the antenna down while traveling as well as to remove the cable. The RAMI AV-3 has a 27" whip and needs to be tuned by cutting to length. The AV-7 is 44" in length and is pre-tuned for freqs 118-137.
Any other cheaper options as these RAMI antenna's are expensive. I will also need a cable extension as they only come with 17'.
Anyone with experience in this area and can provide some guidance?
I will be using this on a hand held Yeasu FTA-450L com radio.
Thanks, Don
P.S. if you are looking for a good handheld that will scan freqs the FTA-450L is great. More features than Icom and much cheaper. On sale with a $25 rebate at Sarasota Avionics till the end of Dec.
http://sarasotaavionics.com/avionics/fta450l
Old December 9th 17, 04:29 AM posted to rec.aviation.soaring
2G
Thanks, Don
https://www.amazon.com/gp/offer-list...&condition=new
Old December 9th 17, 10:57 PM posted to rec.aviation.soaring
Tim Newport-Peace[_4_]
RV.=
fabr=
while=
an=
is
=20
a=
=20
Anyone with experience in this area and can provide some guidance?=20
=20
I will be using this on a hand held Yeasu FTA-450L com radio.=20
=20
Thanks, Don
https://www.amazon.com/gp/offer-list...lp_new_mbc?ie=
=3DUTF8&condition=3Dnew
The AV-7 is (it says) a 5/8 wave antenna. Taking the mid-band frequency of
127MHz, this equates to a wavelength of 2.24m so 5/8 wavelength is 1.4m,
which is 55 inches. The maximum length of the AV-7 is 44 inches. How does
that work?
For the AV-3, a 1/4 wave antenna, the length would be 22 inches, which is
within the maximum length of the AV-3.
Either a 1/4 wave or 5/8 wave antenna still needs to be a resonant length
for the required frequency for best performance. The only such Airband
antenna that I have ever seen tha did not require tuning was an Array using
rods of different lengths, which is not what the AV-3 or AV-7 are.
Tim Newport-Peace
http://www.newportpeace.co.uk/icom.htm
Old December 10th 17, 04:25 PM posted to rec.aviation.soaring
Mike the Strike
RV.=
fabr=
while=
an=
is
=20
a=
=20
=20
=20
Thanks, Don
that work?
Tim Newport-Peace
A 5/8 antenna is typically resonated by adding a base inductor with a tap to match the usual 50-ohm feedline. It's possible to design a nominally 5/8 antenna with a shorter whip and larger inductor, with possibly other matching means to provide a more broadband match.
That's one explanation - another is the specs could be completely made-up!
Old December 10th 17, 06:11 PM posted to rec.aviation.soaring
Darryl Ramm
RV.=
fabr=
while=
an=
is
=20
a=
=20
=20
=20
Thanks, Don
that work?
Tim Newport-Peace
And you get less than the free space 5/8 wavelength due to real-world effects, antenna end effects and physical diameter. That correction is usually less than a 10% shortening. In this case the antennas seem to be made to magnetic mount on a car or other vehicle and i wonder if they assume that and are tuned to correct for that ground plane effect. Yep 5/8 antennas don't need a ground plane, but having one close by changes the tuning.
Old December 11th 17, 01:09 AM posted to rec.aviation.soaring
yes amazing! using a cheap radio shack SWR meter and "tuning" a 1/4, 5/8 or evan a full wave antennae, makes such a big improvement in the reception and transmit functions that my motorhome 1/4 wave magnetic mount with a 18 gauge 18"x18" ground plane siliconed to the roof is getting me 100 mile reception and transmit functions on a terra 720tx radio.
Old December 11th 17, 04:05 AM posted to rec.aviation.soaring
2G
Here is some good info on how to construct a ground plane:
http://www.ai4ji.com/Projects/antennas/groundplanes.htm
Mobile Aviation Weather Felix Piloting 30 November 5th 07 11:43 PM
FA: New VHF 760ch COM radio with mobile antenna aieo Aviation Marketplace 0 March 3rd 07 12:38 PM
FA: Aviation Band Unicom - Transceiver - Mobile or Base OH Aviation Marketplace 2 April 18th 04 02:41 PM
FA: 2- 760ch VHF Aviation Radios Unicom Base Mobile OH Aviation Marketplace 0 March 10th 04 01:56 PM
FA: 760ch VHf aviation radio transceiver mobile-base OH Aviation Marketplace 0 March 2nd 04 01:48 AM
