Winch Weak Link Strengths
Old December 7th 17, 02:27 PM posted to rec.aviation.soaring
Kevin Neave[_2_]
Default Winch Weak Link Strengths
Does anyone out there know how German Glider Manufacturers calculate the
max weak link strength for winching?
Presumanbly this is also related to the max winch speed
For example in the UK the max winch speed of a K13 depends on which weak
link (Brown or Black) is being used
Regards
KN
Old December 7th 17, 03:08 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Regards
KN
Download CS22 (previously JAR22) and search for "weak link" using find function.
"CS 22.583 Winch-launching" describes the conditions.
TOST also has a table on weak link strength on p. 16 of their catalogue giving rated load (in decaNewton). Multiply by 2.2481 to get Pounds.
Gliding New Zealand has a useful "advisory circular weak links" with examples and a rule of thumb.
Old December 7th 17, 06:31 PM posted to rec.aviation.soaring
Bob Kuykendall
On Thursday, December 7, 2017 at 7:08:15 AM UTC-8, Dan Daly wrote:
...Multiply by 2.2481 to get Pounds.
With Brexit and all, is there a formula to convert to Euros?
Old December 7th 17, 07:53 PM posted to rec.aviation.soaring
WB
Sawzall.
Old December 8th 17, 08:49 AM posted to rec.aviation.soaring
Kevin Neave[_2_]
With Brexit and all they're heading for parity
Thanks Dan for the link to CS22.
I think the bit I wanted is CS 22.581 (b)(2)
The ultimate strength of the weak link must be not less than 1.3 x Max
weight.
So for a Max weight of 565kg weak link should be 735kg
Regards
KN
Sawzall.
Old December 8th 17, 01:04 PM posted to rec.aviation.soaring
AS
weight.
Regards
KN
So the glider will take off at 565kg plus 735kg = 1300kg?? Wow!
Sorry - I couldn't resist! I always cringe when I see mass and force happily mixed and used interchangeably. There is a reason why Tost calls out the weak links in daN.
Uli
'AS'
Weak link - single or reserve? Tom Nau Soaring 20 January 19th 08 07:34 PM
Weak link for PW-5 Nyal Williams Soaring 4 June 1st 04 08:46 AM
Weak link for winch launch - 1-26E??? Mark Zivley Soaring 4 April 29th 04 11:38 PM
Realistic Strengths of Homebuilt Carbon Fiber? BllFs6 Home Built 5 March 31st 04 05:23 PM
Blanik Weak Link for Winch Launch??? Gary Emerson Soaring 6 February 24th 04 08:08 PM
