Saved by a steep slope?
Old December 31st 17, 08:33 AM posted to rec.aviation.soaring
Bruce Hoult
Default Saved by a steep slope?
The New Zealand press is reporting an unusual crash. They say the glider suffered catastrophic wing failure (most unusual in itself!), fell out of control 1500 ft onto the steep side of a mountain, and the two occupants escaped the crash without serious injury.
https://www.stuff.co.nz/national/100...th-of-blenheim
p.s. it drives me crazy when the press report "about 457 metres", an extraordinarily precise number, when clearly someone estimated "1500 feet" to an accuracy of possibly not more than 500 feet. Perhaps if US-based organisations report on this crash they will say "about 1499.34 feet" :-) :-)
Old December 31st 17, 12:24 PM posted to rec.aviation.soaring
Kiwi User
https://www.stuff.co.nz/national/100...e-from-glider-
crash-south-of-blenheim
feet" :-) :-)
Any idea what the motor glider was?
It looks a bit like an SF-25 to me, but are there any in NZ?
Martin | martin at
Gregorie | gregorie
| dot org
Old January 1st 18, 05:33 PM posted to rec.aviation.soaring
I don't think there ever was a SF-25 with a ballistic recovery parachute, but there is a microlight version, the SF-40 Mini-Falke, which has one. Not really a motor glider any more, though.
Example: https://www.ulforum.de/ultraleicht/f...lke-sf-40.html
Martin | martin at
Gregorie | gregorie
| dot org
Old December 31st 17, 01:17 PM posted to rec.aviation.soaring
Ross[_3_]
There is a Stemme S10 based at Blenheim, and possibly one of the few options around that might have a ballistic parachute.
Just guessing though.
Old December 31st 17, 04:49 PM posted to rec.aviation.soaring
Pretty lucky for them, but I can believe the story.
Late 70's, had a HS friend in the military, he was doing a routine parajump and had a streamer. He hit near the top of an earthen dam and rolled down.
Result......broken ankle and a medical discharge. Kinda hard to do your "job" when the landing/running gear is compromised.
If he had hit flat ground, more than likely dead.
Sucks to lose an airframe, great the two of them basically walked away...... it was a, "not your time yet, make every day count" sorta thing.
Slope soaring Mt. Hood GARY BOGGS Soaring 2 August 9th 09 04:26 PM
Artificial slope soaring 5Z Soaring 5 June 12th 08 11:13 PM
Dual glide slope, $95...priceless! Jack Allison Owning 20 October 22nd 06 03:45 AM
Glide Slope Antenna Ground Plane JKimmel Home Built 6 August 1st 06 01:28 AM
En route glide slope? Andrew Gideon Piloting 17 November 21st 04 05:49 PM
