Cessna CitationJet/M2
Old January 2nd 18, 03:23 PM posted to alt.binaries.pictures.aviation
Miloch
Default Cessna CitationJet/M2
https://en.wikipedia.org/wiki/Cessna_CitationJet/M2
The Cessna CitationJet/M2/CJ series (Model 525) are light business jets part of
the Cessna Citation family, built by the Cessna Aircraft Company. Its variants
are marketed under the CJ, CJ1, CJ1+, M2, CJ2, CJ2+, CJ3, CJ3+, CJ4 and CJ4+
names. As of June 2017, 2,000 have been delivered with five million hours flown.
The CitationJet is a low-wing cantilever monoplane with retractable
trailing-link tricycle landing gear, a pressurized cabin, a T-tail, and is
powered by two Williams FJ44 turbofan engines that are pylon mounted on the rear
fuselage. Basically an all new aircraft, the CitationJet used a modified version
of the Citation's forward fuselage, but with a new supercritical laminar flow
wing, and a new T-tail configured tailplane. It features EFIS avionics and
single pilot certification. The CitationJet's fuselage is 11 inches (27 cm)
shorter than the Citation I's, but has a lowered center aisle for increased
cabin height.
Role
Business jet
National origin
United States
Manufacturer
Cessna
First flight
29 April 1991
Status
Active, In production
Produced
1991-present
Number built
2000 as of June 8, 2017
Unit cost
M2: US$4,500,000 (2015)
CJ2+: US$7,044,000 (2012)
CJ3+: US$7,995,000
CJ4: US$8,995,000 (2015)
Developed into
Cessna 526 CitationJet
Citation M2
Model 525 marketed as Cessna Citation M2 are powered by improved FJ44-1AP-21
turbofans offering 10 to 15% more cruise thrust and up to 5% more hot-and-high
thrust, and are equipped with modern Garmin G3000 avionics replacing Rockwell
Collins Pro Line 21. Launched in September 2011, it is based on the then
out-of-production CJ1 variant and features a new cabin layout and a more
efficient FJ44 version. The initial M2 prototype first flew on 9 March 2012, it
was not a conforming airframe but was testing the Garmin G3000 avionics and
Williams FJ44-1AP-21 turbofans while one another aircraft was expected to join
the certification program in May 2012 to be used for aerodynamics testing. With
150 produced since introduction in 2013, it became Cessna's entry-level jet
after the Citation Mustang stopped production in May 2017.
Specifications
model M2
Crew Single Pilot Certified
Maximum Passengers 7
Length 42 ft 7 in (12.98 m)
Height 13 ft 11 in (4.24 m)
Wingspan 47 ft 3 in (14.40 m)
Wing Area 240 ft² (22.3 m²)
Wing Sweep 0 degrees 12.5 degrees
Cabin height 57 in (1.45 m)
Cabin width 58 in (1.47 m)
Cabin length 11 ft (3.35 m)
Maximum Takeoff Weight 10,700 lb (4,853 kg)
Maximum Landing Weight 9,900 lb (4,491 kg)
Maximum Zero Fuel Weight 8,400 lb (3,810 kg)
Usable Fuel Weight 3,296 lb (1,495 kg)
Usable Fuel Volume 492 gal (1,862 l)
Basic Operating Weight 6,990 lb (3,171 kg)
Useful Load 3,810 lb (1,728 kg)
Maximum Payload 1,410 lb (640 kg)
Full Fuel Payload 514 lb (233 kg)
Turbofan × 2 Williams FJ44-1AP-21
Thrust (each) 1,965 lb (8.74 kN)
Maximum Cruise 404 ktas (748 km/h)
Maximum Range 1,550 nm (2,871 km)
Takeoff Field Length 3,210 ft (978 m)
Landing Distance 2,590 ft (789 m)
Maximum Operating Altitude 41,000 ft (12,497 m)
Maximum Climb Rate 3,698 fpm (18.8 m/s)
Cessna 210 pics [04/12] - A Cessna T210L shows the later models' strutless cantilever wing.jpg (1/1) Miloch Aviation Photos 0 December 26th 17 03:42 PM
Cessna 210 pics [03/12] - A Cessna P210N Pressurized Centurion with its distinctive small windows.jpg (1/1) Miloch Aviation Photos 0 December 26th 17 03:42 PM
Cessna 140 pics 1 [05/11] - Cessna 120 N76000 at PAFA Fairbanks International Airport.jpg (1/1) Miloch Aviation Photos 0 October 30th 17 11:27 AM
Cessna 525 Citationjet Glenn[_2_] Aviation Photos 1 December 27th 09 10:13 AM
For Sale Cessna CitationJet Mark Aviation Marketplace 1 August 21st 03 12:29 AM
