https://en.wikipedia.org/wiki/Harlow_PJC-2
The Harlow PJC-2 was a 1930s American four-seat cabin monoplane, designed by Max Harlow. Max Harlow was an aeronautical engineer and instructor at the Pasadena Junior College. Under his tutelage, the aircraft designated PJC-1 was designed and built as a class project. The PJC-1 first flew on 14 September 1937 at Alhambra, California but it crashed during an extended (more than six turn) spin test with the center of gravity ballasted to the aft limit, as it was going through the certification process—a problem generally laid at the feet the unusually rigorous spin test requirement and the government test pilot, who bailed out of the airplane after the spin "flattened out." The airplane struck the ground, still in the "flat" (longitudinally level) attitude in a bean field near Mines Field (now Los Angeles International Airport) with considerable damage; although repairable, the PJC-1 was never returned to service. PJC students then built a slightly modified airplane, which limited aileron travel with full aft-stick and incorporated a slightly larger vertical stabilizer. This became the PJC-2 model, serial number 1 certified by the FAA on 20 May 1938. It was one of the first, if not the first, airplane designed and built in the U.S. with a stressed-skin semi-monocoque structure—a revolutionary design feature for the time. Harlow saw the potential and formed the Harlow Aircraft Company to build PJC-2 aircraft at Alhambra Airport. Four aircraft were impressed into United States Army Air Forces service with the designation UC-80 in 1942, and used by Civil Aeronautics Administration inspectors after WW II. Role Four-seat cabin monoplane Manufacturer Harlow Aircraft Company Designer Max B. Harlow First flight 1937 Number built 11 Unit cost $24,880 in 1938 Variants Harlow PC-5 The PJC-2 was an all-metal low-wing cantilever monoplane with conventional low-set tailplane and a retractable tailwheel landing gear. A tandem two-seat version intended as a military trainer was developed as the Harlow PC-5. In 1991, 3 PJC-2s were actively flying. Specifications Harlow PJC-2 General characteristics Crew: One Capacity: Three passengers Length: 23 ft 4 in (7.11 m) Wingspan: 35 ft 10 in (10.92 m) Height: 7 ft 8 in (2.34 m) Wing area: 185 ft2 (17.19 m2) Empty weight: 1661 lb (753 kg) Gross weight: 2600 lb (1179 kg) Powerplant: 1 × Warner Super Scarab SS-50 7-cylinder radial piston engine, 145 hp (108 kW) Performance Maximum speed: 160 mph (257 km/h) Cruise speed: 140 mph (224 km/h) Range: 490 miles (788 km) Service ceiling: 15,500 ft (4725 m) * |
| Thread Tools | |
| Display Modes | |
| UK2 DR424 Harlow PC-5A JackMeadenColl.jpg | Joseph Testagrose | Aviation Photos | 1 | September 4th 13 09:08 AM |
| UK2 DR423 Harlow PC-5A JackMeadenColl.jpg | Joseph Testagrose | Aviation Photos | 0 | March 31st 12 01:44 PM |
