Fabrication by Consensus
Old July 17th 04, 11:23 PM
Veeduber
Default Fabrication by Consensus
Back when the world was young and I still had hair the Navy hired a gaggle of
eggheads to contribute to the design of what eventually became the
Spruance-class of destroyers (i.e., DD-963 class). At that time I was the
Leading Chief of the computer shop for Pac Fleet's cruiser-destroyer force. I
was told to give the eggheads access to anything they wanted in the way of
maintenance and repair data, which I did with a cheery aye-aye, sir.
Marvelous stuff, watching those eggheads at work, doing their computerized
statistical analysis of equipment failures, tracking everything back to the
manufacturer on one hand and the Navy schools on the other.
The product of their work was a list of recommended equipment to go into the
new ships; only the best stuff as determined by its failure rate, required
maintenance man-hours, mean time to repair and so forth.
Which was all bull****, unfortunately.
At that time (early 1970's) ComCruDesPac had about 137 ships. The analysis
covered such things as electric motors, pumps, air compressors, ammo hoists and
so forth, the ancillary systems that are the glue of a modern-day warship.
(The hull design and the turbine powerplants were determined by other groups.)
The objective of the study was to determine the best of that equipment and on
the surface, their methods of analysis appeared valid. But in providing them
with data I noticed that while all destroyers had high-pressure air compressors
(for example) some of them had never failed. (Not many... four, I think.)
Same thing for the other components. All of the ships used a certain type of
gear-head motors but a few ships had never reported any problems with them.
Which brings up a point worthy of mention.
Even though built to the same plan, vessels within a given class are not
identical. The ships are built at different yards and while their specs were
identical their equipment came from a variety of manufacturers. In the case of
electric motors for example, while most of the ships used motors from General
Electric or Westinghouse a few of them had motors from manufacturers I'd never
heard of. The key point here is that some ships had never reported any form of
failure for certain pieces of equipment.
The bottom line is that the study failed to consider the possibility that some
equipment had never failed. Their final report identified only equipment that
HAD failed, giving high marks for designs and manufacturers that failed the
least often.
Which completely ignored the Really Good Stuff.
So what's all that got to do with airplanes? Quite a bit, when it comes to
home-builts.
A fairly common thread on various aviation-related mailing lists and newsgroups
is someone polling the subscribers in hopes of determining the ‘best'
....whatever. The best way to paint a spam can; the best brand of tire; the
best vacuum pump and so on. Which gets down-right scary at times. (One such
poll decided that the ‘best' aluminum was 6061 :-)
Polls and surveys, and the methods of statistical analysis that supports them,
are valid tools. But only when your sample is an accurate reflection of the
population being polled. Ask a room-full of pre-schoolers to define a balanced
diet, don't be surprised if the answer is graham crackers and milk. In a
similar vein, wood makes the best fuselage (according to builders of Pietenpol
‘Air Campers'), welding is easy (according to experienced weldors) and
flying is inexpensive (according to people earning $100k p/a or more). In the
case of the New Ship Design Study Group they failed to include the entire
population of ancillary equipment, inadvertently limiting their investigation
to equipment having a history of failure.
SO WHAT'S THE POINT?
The Internet offers unprecedented access to information but does not provide
any means of determining if that information is valid. Indeed, within the
field of home-built aviation only a small percentage - - probably less than
five percent - - of the available information is valid and even then, only in a
particular case. The remainder is either skewed by commercial interest or is a
reflection of ‘conventional wisdom,' wherein the poster is simply parroting
something they have heard.
Common sense has become remarkably uncommon stuff in modern-day America. Given
the risk inherent in rising above the ground on wings I believe the wiser
course is to treat ALL information on the internet as invalid until you can
test it yourself. Fortunately, with a technical subject such as aviation the
required tests are fundamental and well defined. For the homebuilder,
especially those lacking an engineering background, the tricky bit is devising
methods of applying such tests to their particular situation.
-R.S.Hoover
PS - - So what happened with regard to selecting failure-prone equipment? I've
no idea. By the time the first of the new class slid down the ways I'd been
retired for a number of years. But it's interesting to note that several of
the Spruance-class have been scraped after barely twenty years service. (Navy
ships are designed for a minimum service life of thirty years.)
I identified the Really Good Stuff aboard our own ships and submitted a report
on the matter, producing a minor controversy with regard to maintenance.
Sailors know what I'm talking about and it really doesn't apply to anyone else.
Old July 18th 04, 01:45 PM
Whunicut
snipped
snipped
Something similiar happened on an Essex class carrier I was on when the steam
powered winch handling the high-line was replaced with an electric winch.
Never knew who the "genius" was that was responsible for that FU but the next
time we were in the yards, back came the old steam winch.
Much more responsive than the electric winch and could reverse at full speed.
pretty handy to have when you`ve got a net full of 500 pounders coming aboard
and the seas are running heavy!
`Course that was before your time.:-))
Wh
Old July 18th 04, 06:47 PM
Whunicut
Damn, but they had heavy sailors back then... :-)
Ron "See 'Sailor Obesity' Thread" Wanttaja
LOL :-))
Wh
Old July 19th 04, 04:59 AM
Dave S
Whunicut wrote:
snipped
snipped
Wh
I was never a squid... and while I try to be someone educated on
military stuff.. I just have to ask..
A net full of 500 pound "WHATS???"
Dave
Old July 19th 04, 07:58 AM
Bombs. Rumor has it the Air Force had 'em too.
Old July 19th 04, 01:12 PM
Whunicut
Rotund Flag Officers!
No! Wait!
Rons right. Bums!
Wh
Old July 18th 04, 10:11 PM
Bob Chilcoat
Many years ago now, the FDA discovered that with the advent of their new
computer system they could do quick retrospective studies of various drugs
to see which were most closely associated with death of the patient. Which
drugs were the most dangerous. The first study they undertook looked at
correlations between a large variety of drugs and sudden death in the
operating room. The data were entered, the numbers crunched, and it was
discovered (surprise!) that the most dangerous drug, with nearly a 100%
correlation with sudden death in the operating room was (wait for it... )
Oxygen. Virtually every patient who died in the operating room had received
oxygen.
Correlations are not necessarily cause and effect. Also, be very careful
that your study is designed to tell you what you want to find out.
Bob (Chief Pilot, White Knuckle Airways)
I don't have to like Bush and Cheney (Or Kerry, for that matter) to love
America
"Veeduber" wrote in message
of
force. I
analysis
hoists and
warship.
groups.)
on
them
compressors
of
them.
were
case of
General
never
form of
some
that
least often.
to
home-builts.
newsgroups
is someone polling the subscribers in hopes of determining the 'best'
such
poll decided that the 'best' aluminum was 6061 :-)
them,
balanced
Pietenpol
'Air Campers'), welding is easy (according to experienced weldors) and
investigation
provide
than
in a
is a
reflection of 'conventional wisdom,' wherein the poster is simply
parroting
Given
can
devising
-R.S.Hoover
I've
been
of
(Navy
report
else.
