VTOL Electric Aircraft
Old February 9th 18, 04:39 AM posted to rec.aviation.soaring
2G
Default VTOL Electric Aircraft
Dale Kramer proposed a kickstarter funder VTOL aircraft a couple of years ago (https://www.kickstarter.com/projects...ertical-takeof) that I had a number of serious concerns over. While the kickstarter was unsuccessful, it is worth noting that such an aircraft has being successfully developed in China:
https://www.avweb.com/avwebflash/new...-230280-1.html
Their idea of "long range" is only 6 miles!
Tom
Old February 9th 18, 11:46 AM posted to rec.aviation.soaring
Kiwi User
years ago
(https://www.kickstarter.com/projects...vlazair-model-
of-230mph-3hr-flight-vertical-takeof)
https://www.avweb.com/avwebflash/new...TOL-Passenger-
Flights-230280-1.html
That thing scares me silly - not so much in the air, but the thought of
mixing people's legs with those knee-level, unguarded rotors just looks
like an accident waiting to happen.
At least with Dale Kramer's VTO thing you didn't have to walk through the
rotors to get into it.
Old February 10th 18, 06:43 AM posted to rec.aviation.soaring
2G
years ago
Have you ever been around power planes? They do have propellers that you can walk into, and people have.
Kramer's idea was a pipe dream that never got off the drawing board - this is a real, working full scale product.
Tom
Old February 10th 18, 12:15 PM posted to rec.aviation.soaring
Kiwi User
Of course - and I've been able to get into all of them, except the SF-25,
without having to walk in front of the wing. On the Chinese thing we have
a set of knee-level unguarded rotor and a way to the cabin that requires
passengers to walk between unguarded rotors along an access part looks to
be 1m wide at the most.
I said and meant 'passengers', i.e. people who are not trained in airside
hazards, because the thing is intended for autonomous operation as well
as being manually flown. These people are likely to unknowingly stand
within the rotor arcs, especially if they are being met or seen off by
third parties.
Old February 10th 18, 02:55 PM posted to rec.aviation.soaring
Whiskey Charlie
Wouldn't easy solution be to just shut off the motors when unloading and offloading passengers? Or put them up high like the "flying taxi" volocopter: https://www.youtube.com/watch?v=qArZGwtRINg
How about a VTOL lightweight glider to use at all those para-glider and hang-glider sites?
Old February 10th 18, 07:47 PM posted to rec.aviation.soaring
Kiwi User
They are off but the walkway is pretty narrow - would yo walk up to the
cabin and get in, knowing that fully charged batteries are connected to
the rotor motors?
And, as you say, why didn't they put the rotors above the cabin like the
volocopter? Apart from anything, that would save wear and abrasion on
motors and rotors when operating from dusty or sandy ground.
I want the inflatable glider suit worn by Kath Two in the final part of
"Seveneves".
Electric self-piloted Airbus VTOL aircraft completes first full-scale test flight Larry Dighera Piloting 1 February 5th 18 02:44 PM
Lilium Aviation flies prototype of its 160-knot all-electric VTOL Larry Dighera Piloting 10 July 9th 17 09:19 PM
CAFE Electric Aircraft Symposium Set For May 1 Larry Dighera Piloting 35 June 5th 15 10:13 PM
SunAero Electric Aircraft Larry Dighera Piloting 0 September 27th 14 04:52 PM
Solar Electric Powered Aircraft Larry Dighera Piloting 33 November 6th 05 08:37 PM
