strange ASI readings on LXNAV s80 vs Winter ASI
Old February 15th 18, 01:38 AM posted to rec.aviation.soaring
Matt Herron Jr.
Default strange ASI readings on LXNAV s80 vs Winter ASI
looking for some instrument debugging help.
I have a steam gauge ASI (winter) and an LxNav S80 sharing the same Pitot and static lines. In the air, the two gauges read ASI differently. The S80 reads about 10 knots higher than the Winter at 70 knots, and 5 knots higher at 40 knots. The error seems to scale with higher airspeeds
Back on the ground we used a syringe to pressurize the pitot line. Both instruments read within 2 knots of each other for the full speed range. they also held steady at the desired airspeed with the syringe, indicating no leaks in the Pitot system.
Back in the air, I tried opening and closing the vent, scooping air into the cockpit to pressurize it, etc. Neither instrument changed its reading, but the offset in speeds remained.
Ideas? Leak in Static?
Matt
Old February 15th 18, 02:07 AM posted to rec.aviation.soaring
Dave Nadler
First, check your static for leaks.
Second, check the instruments against a 3rd reference.
See if they are consistent (doesn't matter if the 3rd
unit is off as long as its consistent).
Hope that helps,
Best Regards, Dave
PS: Once had a customer return an instrument TWICE because
he insisted his Winter ASI was correct -- and of course
when he finally checked it was way off. Winter 2 1/4" ASIs
are notorious (and why a back-seater once said
"gee, if I do this in Condor the wings come off").
PPS: I have a Chinese ASI in the shop that is WILDLY off,
but great for leak-checks...
Old February 15th 18, 02:39 AM posted to rec.aviation.soaring
Paul Remde
Are they connected to the same pitot and static sources? Some gliders use a triple probe in the tail for the soaring flight computer and vario and the pitot in the nose and statics on the fuselage for the airspeed and altimeter.
Also, make sure the S80 is set to display airspeed in knots, not mph.
Best Regards,
Paul Remde
_________________________
Matt
Old February 15th 18, 04:02 AM posted to rec.aviation.soaring
Brian[_1_]
make a water manometer to calibrate them.
http://www.n56ml.com/airspeed_calibration/
Brian
Old February 15th 18, 05:54 AM posted to rec.aviation.soaring
Matt Herron Jr.
Best Regards,
Paul Remde
Matt
yes, they are connected to the same pitot and static sources. That's what is so weird about this
Old February 15th 18, 06:27 AM posted to rec.aviation.soaring
Doug C[_2_]
Matt
Hi Matt:
I experienced the same problem when I received my S100 early last year. Uros sent me the following solution which autozeros the pressure sensors. His suggestions completely solved the problem for me.
Best regards
Doug
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Hello,
please check under setup-vario, that you have airspeed offset set to 0.
Please enter password 01043, to make autozero on pressure sensors.
Best regards, Uros
Old February 15th 18, 07:49 AM posted to rec.aviation.soaring
Paul's units suggestion would fit:
40knots = about 46mph. 70knots = 80mph.
Old February 15th 18, 03:43 PM posted to rec.aviation.soaring
Matt Herron Jr.
Matt
Hi Matt:
Best regards
Doug
Hello,
Best regards, Uros
Thanks Doug, I will give that a try. As far as units go, both instruments indicate knots.
Matt
LXNAV V7 - Reviews? David Reitter Soaring 10 October 21st 14 12:41 AM
New vario by LXNAV [email protected] Soaring 6 May 22nd 13 11:15 PM
LXNAV V7 Paul Remde Soaring 2 November 2nd 11 12:31 AM
Compression readings [email protected] Owning 18 December 15th 04 09:38 PM
Different WAAS altitude readings Wyatt Emmerich Instrument Flight Rules 21 June 29th 04 07:27 PM
