Old Cambridge GPS Nav
Old February 15th 18, 12:48 PM posted to rec.aviation.soaring
Ross[_3_]
Default Old Cambridge GPS Nav
Powered up an old Cambridge GPS Nav today and the LCD Display gives me the warning to check the LCD Cable.
Having done this, made a new cable etc, I have still got no solution to the problem.
Any suggestions other than the rubbish bin?
Cheers
Old February 15th 18, 01:34 PM posted to rec.aviation.soaring
Cheers
Commonly one of the sockets has a problem. Look closely at both. Also do the "stupid" check of making sure the cable has the connectors oriented right. Look at the diagram in the manual carefully and compare.
Good luck
UH
Old February 15th 18, 01:38 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Take the "Windows" approach. Try plugging and unplugging the connector more than a few times. Might be some light corrosion on contacts. Make sure the cable is made correctly. If you have the hardware, try the same logger and cable with a different display. If that doesn't work, post the whole thing to me when you get another batch of radios for me to buy.
Steve Leonard
Old February 15th 18, 03:18 PM posted to rec.aviation.soaring
Dan Marotta
....And shoot some contact cleaner in the sockets and on the pins before
Steve's plug/unplug exercise.
Steve Leonard
Dan, 5J
Old February 16th 18, 07:56 AM posted to rec.aviation.soaring
Ross[_3_]
Problem kinda solved. Thanks for the tips.
When powering the LCD up I need to hold the GO button. Works fine.
If I don't do this it requires a cable check. No idea why but I can live with it the way it is.
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario ufmechanic Soaring 0 March 24th 09 05:31 PM
Cambridge 302 & PDA -- Value of adding Cambridge 303? V1 Soaring 5 July 31st 07 03:51 AM
Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 Nathan Whelchel Soaring 4 July 5th 04 11:22 PM
FS Cambridge CAV-II WDM Soaring 2 March 27th 04 01:55 AM
Cambridge "V" JJ Sinclair Soaring 0 March 11th 04 02:01 PM
