Mini LAK
Old February 18th 18, 12:25 AM posted to rec.aviation.soaring
Default Mini LAK
Does anyone have any experience, knowledge or opinion on the headwind penetration capabilities of the Mini-LAK without the FES. The manufacture advertises a 45/1 L/D with very light 13.5 meter wings. Appreciate any feedback. Thanks.
Old February 18th 18, 06:40 AM posted to rec.aviation.soaring
RossFW
Default Mini LAK
I believe the polar is available on the brochure. TAS - HEAD-WING equals ground speed, same as any other glider.
Old February 18th 18, 07:24 AM posted to rec.aviation.soaring
krasw
Default Mini LAK
sunnuntai 18. helmikuuta 2018 2.25.19 UTC+2 kirjoitti:
45/1? The best 15m gliders can barely touch that figure (talking about real world, not brochures), taking 10% off span does not exactly help. Germans have given MiniLAK same handicap as LS4, which does not contradict things I have heard about performance. But why would anyone fly this wihtout FES? At 35 kg/m2 wingloading "penetration capability" is about same as with paper bag.
Old February 18th 18, 03:21 PM posted to rec.aviation.soaring
Tony[_5_]
Default Mini LAK
A mini LAK with FES will be flying quite a bit higher than 35 kg/m^2. In Hungary all the Mini LAKS flew without FES and we're at the (silly) 35 kg/m^2 limit.
Check out the flight traces for the first day of the 2nd 13.5m WGC. the first turnpoint was directly in to the wind probably about 75km. Wind was at least 20 knots. The Mini LAKs made it. Thise of us in Silents did not.
There was another similar day about Day 8 or so, where the task was a double out and return along a strong NW wind. You can evaluate from the traces how the MiniLAKs handled it. I couldn't write make the last turnpoint into the wind and had to use the motor before the downwind run home.
My assessment from actual (brief) side by side in flight experience is that the miniLAK can work into the wind just fine.
Old February 18th 18, 06:39 PM posted to rec.aviation.soaring
sisu1a
Default Mini LAK
It doesn't seem right at first, but when you look at the ship it's not a 15m ship with the wings clipped to 13.5, it's a 90% scale model of one!
Lx mini map Dave Wallis Soaring 5 February 26th 12 01:25 PM
mini-map Gaetan Trudel Soaring 4 November 22nd 10 04:40 PM
Mini-Imp Curt Fennell Home Built 7 November 10th 09 12:43 PM
Mini-500 Sim Jim Aviation Marketplace 0 January 26th 04 11:32 PM
Mini Imp Randall Robertson Home Built 0 November 25th 03 12:17 AM
