Radios for sale: Becker AR4201 and Vertex Standard VXA-710 (handheld)
Old February 25th 18, 11:56 AM posted to rec.aviation.soaring
Default Radios for sale: Becker AR4201 and Vertex Standard VXA-710 (handheld)
Becker AR4201 230 US-$ excl. shipping
VHF Transceiver, radio for aircraft use
25 kHz channel spacing
760 channels, 118.000 to 136.975 MHz
Output 5 W
Supply Voltage: 12,4 – 15,1 V
Dimensions 60,6 x 60,6 x 192 mm
Made for 57 mm cutout
Weight 670 g
S/N 3497
The radio was dismounted due to the new channel spacing regulation in Germany and a panel upgrade. It was in a good working condition with no recognizable problems.
Includes:
- Radio
- Installation Instruction (German) with “Zulassungsurkunde” (admission certificate)
- Manual (German on paper or PDF, English as PDF)
- Authorized release certificate JAA Form One 26.01.1998
- Plug (RS232, 25 Pin) with cables (cut from panel)
Located in Wuerzburg, Germany. Shipping internationally possible.
__________________________________________________ ________________________
Vertex (Yaesu) Standard VXA-710 Spirit (handheld) 150 US-$ excl. shipping
Air band transceiver / handheld radio
Very small, compact, light weight. Good working condition.
25 kHz channel spacing (air band).
Sold due to new the new channel spacing regulation in Germany.
I loved this radio because all others are much larger. And it can be detached quite fast from belt clip by turning 180°
TX 118.00 – 136.975 MHz with 5 W
RX
- 88.000 - 108.000MHz (FM BC Band),
- 108.000 - 117.975 MHz (NAV Band),
- 118.000 - 136.975 MHz (COM Band),
- 151.5125 - 158.400MHz (BRS Memory Channels),
- Weather Channel (WX-01 – WX-10)
Power supply 4,5 – 15,0 V
Dimensions (case): 60 x 96 x 28,5 mm
Weight: 280 g
Including battery charger and belt clip.
Manual available (PDF, English).
Old February 25th 18, 12:18 PM posted to rec.aviation.soaring
Forgot to link the photos:
Becker: http://glidersource.com/cgi-bin/post.cgi?id=1237
Vertex: http://glidersource.com/cgi-bin/post.cgi?id=1239
Old February 25th 18, 08:16 PM posted to rec.aviation.soaring
Important for other countries: The charger works with 230 - 240 V and delivers DC 12 V 500 mA. So if you need 110 V you have to use a different one or any charger delivering 4,5 - 15 V.
Old February 25th 18, 09:19 PM posted to rec.aviation.soaring
Dan Marotta
Default Radios for sale: Becker AR4201 and Vertex Standard VXA-710(handheld)
Easy enough to clip off the radio plug and splice to a charger from your
own country.* Be careful of polarity.
Dan, 5J
Old March 1st 18, 05:30 PM posted to rec.aviation.soaring
Vertex handheld is sold.
Becker AR4201 is still for sale.
Becker AR4201 for sale Jon Hall Soaring 1 May 26th 17 10:22 PM
Becker AR4201 Transceiver For sale Ian Kennedy Soaring 1 May 25th 17 12:13 AM
FS: Vertex Standard VXA-210 Pilot handheld radio like new $225.00 Aspen37 Aviation Marketplace 1 July 17th 05 06:20 PM
Thoughts on handheld Aviation radios (ICOM vs Vertex-Standard) Barnyard BOb - Home Built 5 September 8th 04 07:27 PM
Thoughts on handheld Aviation radios (ICOM vs Vertex-Standard) Cub Driver Piloting 0 September 8th 04 10:35 AM
