Release from Tow
Old July 8th 04, 09:21 PM
Hal
Default Release from Tow
Doing a electronic declaration for a 300/500k cross country flight is
it possible to have the starting point be "Release from Tow" or does
that require a written declaration. I use the 302.
Old July 8th 04, 11:18 PM
Marc Ramsey
Yes, the release point can be the start point, no written declaration is
required, as the release point will be documented by the flight recorder
(remember to notch, or make a tight 360 degree turn, and also make sure
you don't release so high as to run afoul of the loss of height rules).
Note, however, if you are attempting a triangle or out/return for
Diamond goal, your start and finish points must coincide, which can be
most easily accomplished by either releasing directly over the airport,
or electronically declaring the same waypoint as start and finish.
Marc
Fiberglass release agent? [email protected] Home Built 14 July 9th 04 10:26 PM
Fiberglass / Mold release advice requested Mark Zivley Home Built 10 April 2nd 04 11:15 PM
Air Force Museum Working Group to release final report Otis Willie Military Aviation 0 November 18th 03 12:28 AM
ANN: flyWithCE news release - November 2003 Uros Podlogar Soaring 0 November 16th 03 09:23 AM
XCSOAR Next Release?? Michael Pitoniak Soaring 0 August 4th 03 12:30 AM
