Need Help with some radio problems
Old July 9th 04, 09:21 PM
TJ
Default Need Help with some radio problems
Hi,
I have a Terra 760 that doesn't work.
(Long story if you want to hear it.)
(1) Any idea who fixes these things?
(2) Any suggestions as to problem:
(The LED numbers aren't showning up
as nice distinct numbers. They look
like strike overs and it is hard to
tell if what the frequency is. There
is no sound. Turning volume up and
playing with the sq. and you get no
noise from the speaker (speaker is ok,
I tested it.) It seems to transmit still.
(3) I am going to have to install a older Edo-aire
RT-551A, but I've forgotten the pin out.
Pin 1 appears to be ground (negative)
Pin 15 appears to be positive
Pins 12 and 13 appear to be the mike plug
Pin 6 is ????? (Yellow wire coming out of it)
Pins for speaker ?????
HELP! Am I correct?
Also, while I'm on a "roll"....Does anyone have
a manual for a Bleumineaur (spelling). Older
instrument that runs three heads (one vario, one
something else and one something else).
Thanks!
Thomas
or call 503.638.0384
Old July 10th 04, 01:57 PM
JJ Sinclair
TJ,
Recommend you send the Terra to the local land fill.
Pin-out for your EDO AIR is:
1. Ground (black)
6. Spkr
7. Phones (wht)
12. PTT (grey)
13. Mike (green)
15. + 14 volts (red)
The Edo Air is the best radio around, My crew has one and people turn their
volume down when she transmits with it. Does suck up the amps, though. About 5
on transmit.
Good luck,
JJ Sinclair
(sorta OT) Free Ham Radio Course RST Engineering Home Built 51 January 24th 05 08:05 PM
(sorta OT) Free Ham Radio Course RST Engineering Piloting 43 January 24th 05 08:05 PM
1944 Aerial War Comes to Life in Radio Play Otis Willie Military Aviation 0 March 25th 04 10:57 PM
Radio silence, Market Garden and death at Arnhem ArtKramr Military Aviation 4 February 12th 04 12:05 AM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 03:30 AM
