Flarm collision alert from Tow Plane ADS-B
Old March 16th 18, 09:42 PM posted to rec.aviation.soaring
Default Flarm collision alert from Tow Plane ADS-B
Now that our club tow plane has installed ADS-B out, I’m getting a constant collision alert on my S80, Flarm butterfly and Qudie while on tow. Is there any way to silence the collision alarm while on tow without turning off ADS-B targets on Flarm all together. I like seeing ADS-B targets while flying in congested areas. It would be nice is there was a way to identify specific ADS-B IDs that should not be reported like tow planes. It’s bad enough to just see the Flarm collision alert screen with the red 12 o’clock the whole time on tow, but having the constant beeping is just too much to tolerate.
Old March 16th 18, 09:47 PM posted to rec.aviation.soaring
jfitch
I don't know what the answer is, but masking all tow planes all the time is probably not a good one. There have been a few collisions between tow planes and gliders, those are ones you really want to avoid.
Old March 16th 18, 11:00 PM posted to rec.aviation.soaring
son_of_flubber
What about turning the volume down until you're off tow? If you hook up an external speaker, you could use a SPST switch?
I agree that you don't want to block alerts on the tow plane and you don't want the tow plane to turn off ADS-B out during tow.
Old March 17th 18, 02:41 AM posted to rec.aviation.soaring
George Haeh
If the towplane has [Power] Flarm, the relevant Flarm parameters a
Transponder - Mode S
ICAO ID
Aircraft Type - Towplane
Mind you if the towplane installed UAT, Flarm won't see the ADS-B.
Old March 17th 18, 03:18 PM posted to rec.aviation.soaring
jfitch
ICAO ID
That's for the towplane flarm. My understanding is that this towplane doesn't have flarm, it has ADS-B out. Flarm might be smart enough not to consider a towplane going the same direction 200 ft ahead as a threat, but would not know anything about an ADS-B target. Perhaps this is a request we need to make of the Flarm people - if you could add an ICAO address to the Flarm net data base, Flarm could ID the towplane and do the right thing.
Old March 17th 18, 04:18 PM posted to rec.aviation.soaring
Darryl Ramm
You can add a 1090ES only entry to the FlarmNet database today, and that may help display target IDs in a more friendly way. I don’t have any idea if it makes a difference to actual target handling,
Old March 17th 18, 05:37 PM posted to rec.aviation.soaring
jfitch
So, the assignment for the OP is to try it and report back - more people are going to be having this issue.
Old March 18th 18, 04:15 PM posted to rec.aviation.soaring
Ramy[_2_]
I don’t see the option to enter ADS-B info in flarmnet. This could be useful though. Or perhaps flarm displays already recognize the contest ID for an ADSB target if their flarm already registered in flarmnet?
Ramy
Old March 17th 18, 11:12 PM posted to rec.aviation.soaring
kirk.stant
On Friday, March 16, 2018 at 4:42:59 PM UTC-5, wrote:
(snipped) Is there any way to silence the collision alarm while on tow without turning off ADS-B targets on Flarm all together.
Take shorter tows?
66
Old March 18th 18, 02:01 AM posted to rec.aviation.soaring
I don't know what the answer is, but masking all tow planes all the time is probably not a good one. "There have been a few collisions between tow planes and gliders, those are ones you really want to avoid."
Do you mean at crowded contests or a one off tow or a commercial site with concurrect tows, or what? And where?
Flarm collision avoidance protocol or an 'open source' one? [email protected] Soaring 2 January 24th 08 09:59 PM
US pilots concerned with collision avoidance, read the FLARM threads JS Soaring 12 October 11th 06 05:29 PM
Collision alert! Greg Copeland Piloting 60 August 18th 06 10:39 AM
Plane-crashes because of collision with bees ??? Dan Simper Piloting 18 February 13th 05 07:37 PM
interesting collision alert device Steve / Sperry Soaring 1 March 19th 04 10:31 PM
