Relay
Old July 20th 04, 12:33 AM
David
Default Relay
So I am putting a Batt relay on my plane and it is one that grounds out to
complete the circuit. Is it normal to have it get hot. Not to hot to touch
but pretty hot.
Old July 20th 04, 05:24 AM
Richard Lamb
but pretty hot.
Could be a 'starter' relay.
That kind is intended for non-continuous duty.
But hard to guess trying to feel the screen...
Richard
Old July 20th 04, 05:44 AM
John Ammeter
On Tue, 20 Jul 2004 03:24:07 GMT, Richard Lamb
but pretty hot.
Richard
If I recall correctly and it's been about 15 years since I
built the RV-6... The Master Relay actuates by grounding a
lead. The Start Relay actuates by applying 12 DC positive
to the relay.
The Master is intended for continuous operation while the
Start is only for intermittent operation.
I don't recall the Master Relay getting hot but, then, I
didn't ever attempt to touch it after the engine was
operating...
John Ammeter
Old July 20th 04, 08:35 AM
Barnyard BOb -
but pretty hot.
Other's have weighed in with concerns that you may wrongly be
using a starter solenoid. They normally are grounded... and you
supply it with battery voltage.
OTOH...
What you describe that requires grounding to function, sounds
exactly like a bona fide batt relay and they do get quite warm....
but not so hot as to give your finger a blister.
Barnyard BOb -
Old July 20th 04, 01:29 PM
Richard Lamb
but pretty hot.
OTOH...
Barnyard BOb -
Aw rats. I do believe BooB is right.
Dam defective brain cells let me down again.
Richard (or what's left of him)
Old July 20th 04, 05:11 PM
jls
"Barnyard BOb -" wrote in message
to
touch
but pretty hot.
Other's (sic) have weighed in with concerns that you may wrongly be
For a relay to work, it is grounded. Matter of practicality. Otherwise
how would you complete the circuit?
OTOH...
When you run current through a wire coil and complete a circuit, in this
case an electromagnet contactor, a by-product is heat. Resistors make
heat. Unavoidable.
Barnyard BOb -
Switching radios on 1 antenna Nicholas J. Hirsch Home Built 16 June 14th 04 02:49 PM
Electrical Relay Help Jeff Home Built 10 August 29th 03 05:03 AM
