Correct adhesive to use to attach tail wheel assembly.
Old April 1st 18, 05:49 AM posted to rec.aviation.soaring
Cookie
Default Correct adhesive to use to attach tail wheel assembly.
3M makes a heavy duty double sided foam tape it is used to attach fender flairs and suff on cars and trucks...works great... git it in auto parts store
On Saturday, March 31, 2018 at 9:56:11 PM UTC-4, wrote:
I recently sheared off the tailwheel assembly on my LS 3a by applying a small side load to the tail while ground handling. The tailwheel has a rubber base that is glued to the fuselage and a roller blade type wheel below. The base
clearly functions as a shock absorber and the entire assembly is designed to shear off in a ground loop. I ordered a replacement tailwheel assembly and used a 3M brand spray contact cement to mount the wheel assembly. I gave it 24 hours to cure and was able to pull the assembly off of the fuselage with very little force. There was no residue of the contact cement on the wheel assembly. Clearly, the contact cement did not adhere to the rubber. Can anyone tell me the proper type of contact cement to use for this application?
Paul Stiles 9P
Correct adhesive to use to attach tail wheel assembly. Tony[_5_] Soaring 7 April 3rd 18 03:05 AM
Correct adhesive to use to attach tail wheel assembly. NG[_2_] Soaring 0 April 1st 18 03:36 AM
ASW 19 tail wheel [email protected] Soaring 13 September 20th 16 11:09 PM
spare tail dolly wheel assembly [email protected] Soaring 3 February 19th 15 02:29 PM
FS: Blanik L-13 Tail Skid & Tail Wheel Assembly Tim Hanke Soaring 0 February 8th 05 01:34 PM
