Junkers Ju 86
Old April 6th 18, 02:48 PM posted to alt.binaries.pictures.aviation
Miloch
Default Junkers Ju 86
https://en.wikipedia.org/wiki/Junkers_Ju_86
The Junkers Ju 86 was a German monoplane bomber and civilian airliner designed
in the early 1930s, and employed by various air forces on both sides during
World War II. The civilian model Ju 86B could carry ten passengers. Two were
delivered to Swissair and five to Deutsche Luft Hansa. In addition a single
civilian Ju 86Z was delivered to Sweden's AB Aerotransport.
In 1934, a specification for a modern twin-engined aircraft, capable of
operating both as a high speed airliner for the German airline Luft Hansa and as
a medium bomber for the nascent Luftwaffe, was issued to both Junkers and
Heinkel. Five prototypes were ordered from each company; the Junkers Ju 86 and
Heinkel He 111. Junkers' design was a low-winged twin engined monoplane, of
all-metal stressed skin construction. Unlike most of Junkers' previous designs,
it discarded the typical corrugated skinning in favour of smooth metal skinning
which helped to reduce drag. The craft was fitted with a narrow track
retractable-main gear conventional undercarriage with a fixed tailwheel, and
twin fins and rudders. It was intended to be powered by Junkers Jumo 205 diesel
engines, which although heavy, gave better fuel consumption than conventional
petrol engines.
The distinctive Junkers-utilized doppelflügel control surfaces on the Ju 86's
wing, much as the Ju 52 always used, were hinged below the wing's trailing edge,
with the outboard section on each side functioning as an aileron, and the inner
section functioning as a wing flap. The bomber aircraft had a crew of four; a
pilot, navigator, radio operator/bombardier and gunner. Defensive armament
consisted of three machine guns, situated at the nose; at a dorsal position; and
within a retractable ventral position. Bombs were carried vertically in four
fuselage cells behind the cockpit. The airliner version replaced the bomb cells
with seating for ten passengers, with fuel tanks being moved from the fuselage
to the wings.
Early use of the Jumo-powered Ju 86 bomber in the Spanish Civil War showed that
it was inferior to the He 111, with the diesel engines being unsuitable for
rough treatment during combat; and production plans were cut back. One Ju 86 had
already been converted to use radial engines as a testbed for possible export
versions, and this showed much improved reliability. Production switched to a
version powered by the BMW 132 engine, the Ju 86E, production continuing until
1938.
Role
Bomber, Airliner, Reconnaissance aircraft
Manufacturer
Junkers
Designer
Ernst Zindel
First flight
1934
Introduction
1936
Status
retired
Primary user
Luftwaffe
Number built
~900
The bomber was field tested in the Spanish Civil War, where it proved inferior
to the Heinkel He 111. Four Ju 86D-1s arrived in Spain in early February 1937,
but after a few sorties one of them was shot down on 23 February by Republican
fighters with the loss of three crewmen killed and one captured. A replacement
aircraft was sent from Germany, but in the summer of 1937 another was lost in an
accident, and the three remaining aircraft were sold to the Nationalist air
forces. Ju 86s were again used in the 1939 invasion of Poland, but retired soon
after. In January 1940, the Luftwaffe tested the prototype Ju 86P with a longer
wingspan, pressurized cabin, Junkers Jumo 207A-1 turbocharged two-stroke,
opposed-piston diesel engines and a two-man crew. The Ju 86P could fly at
heights of 12,000 m (39,000 ft) and higher on occasion, where it was felt to be
safe from enemy fighters. The British Westland Welkin and Soviet Yakovlev
Yak-9PD were developed specifically to counter this threat.
Junkers developed the Ju 86R for the Luftwaffe, using larger wings and new
engines capable of even higher altitudes - up to 16,000 m (52,500 ft) - but
production was limited to prototypes.
Specifications (Ju 86 R-2)
General characteristics
Crew: 2 (pilot and radio operator)
Length: 16.46 m (54 ft)
Wingspan: 32 m (105 ft)
Height: 4.7 m (15 ft 5 in)
Wing area: 97.5 m² (1,049 ft²)
Empty weight: 6,758 kg (14,900 lb)
Max. takeoff weight: 11,530 kg (25,420 lb)
Powerplant: 2 × Junkers Jumo 207B-3 diesel engines, 746 kW (1,000 hp) each
Performance
Maximum speed: 420 km/h (261 mph) above 9,000 m (29,527 ft)
Range: 1,580 km (980 mi)
Service ceiling: 14,400 m (47,244 ft)
Rate of climb: 4.67 m/s (920 ft/min)
Armament
Guns:
1 x 7.92 mm (0.31 in) MG 17 machine gun remotely controlled in rear fuselage,
firing aft
Bombs: Up to 1,000 kilograms (2,200 lb) of ordnance in four internal ESAC 250
bays rated at 250 kg (550 lb) each 4 × 250 kg (551 lb) (1,000 kg/2,204 lb total)
16 × 50 kg (110 lb) (800 kg/1,764 lb total)
64 × 10 kg (22 lb) (640 kg/1,410 lb total)
Junkers G.38 pics 2 [06/10] - Junkers G_38 passenger dining with steward.jpg (1/1) Miloch Aviation Photos 0 February 16th 18 03:13 PM
Junkers G 31 pics 2 [16/16] - The interior of the Junkers G.31 freight carrier supplied to Guinea Airways, Ltd.jpg (1/1) Miloch Aviation Photos 0 November 18th 17 03:26 PM
Junkers G 31 pics 1 [08/12] - Junkers equipped as a Red Cross machine with eight berths and a chair for the attendant.jpg (1/1) Miloch Aviation Photos 0 November 18th 17 03:23 PM
Junkers Ju 52 more [14/14] - Junkers-Ju-52-3mg5eW-DR+WO-being-flight-tested-prior-to-delivery-to-a-Seetransportstaffel-02.jpg (1/1) Miloch Aviation Photos 0 July 24th 16 03:51 PM
Junkers Ju 52 pics [21/21] - Junkers-Ju-52-3mg5eW-DR+WO-being-flight-tested-prior-to-delivery-to-a-Seetransportstaffel-02.jpg (1/1) Miloch Aviation Photos 0 July 24th 16 03:40 PM
