https://en.wikipedia.org/wiki/Arado_Ar_196
The Arado Ar 196 was a shipboard reconnaissance low-wing monoplane aircraft built by the German firm of Arado starting in 1936. The next year it was selected as the winner of a design contest and became the standard aircraft of the Kriegsmarine (German navy) throughout World War II. In October 1936, the Reichsluftfahrtministerium (German Air Ministry, RLM) asked for a He 114 replacement. The only stipulations were that it would use the BMW 132, and they wanted prototypes in both twin-float and single-float configurations. Designs were received from Dornier, Gotha, Arado and Focke-Wulf. Heinkel declined to tender, contending that the He 114 could still be made to work. With the exception of the Arado low-wing monoplane design, all were conventional biplanes. This gave the Arado better performance than any of the others, and the RLM ordered four prototypes. The RLM was conservative by nature, so they also ordered two of the Focke-Wulf Fw 62 designs as a backup. It quickly became clear that the Arado would work effectively, and only four prototypes of the Fw 62 were built. The Ar 196 prototypes were all delivered in summer 1937, V1 (which flew in May) and V2 with twin floats as A models, and V3 and V4 on a single float as B models. Both versions demonstrated excellent water handling and there seemed to be little to decide, one over the other. Since there was a possibility of the smaller outrigger floats on the B models "digging in", the twin-float A model was ordered into production. A single additional prototype, V5, was produced in November 1938 to test final changes. Ten A-0s were delivered in November and December 1938, with a single 7.92 mm (.312 in) MG 15 machine gun at the rear seat for defense. Five similarly equipped B-0s were also delivered to land-based squadrons. This was followed by 20 A-1 production models starting in June 1939, enough to equip the surface fleet. Role Reconnaissance Manufacturer Arado Designer Walter Blume First flight May 1937 Introduction November, 1938 Primary users Kriegsmarine Bulgarian Air Force Finnish Air Force Romanian Air Force Produced 1938–44 Number built 541 The plane was loved by its pilots, who found that it handled well both in the air and on the water. With the loss of the German surface fleet, the A-1s were added to coastal squadrons and continued to fly reconnaissance missions and submarine hunts into late 1944. Two notable operations were the capture of HMS Seal, and the repeated interception of RAF Armstrong-Whitworth Whitley bombers. Although it was no match for a fighter, it was considerably better than its Allied counterparts, and generally considered the best of its class. Owing to its good handling on water, the Finnish Air Force utilized Ar 196s just for transporting and supplying special forces patrols behind enemy lines, landing on small lakes in remote areas. Several fully equipped soldiers were carried in the fuselage. Specifications (Ar 196 A-2) General characteristics Crew: two (pilot and observer) Length: 11 m (36 ft 1 in) Wingspan: 12.4 m (40 ft 8 in) Height: 4.45 m (14 ft 7 in) Wing area: 28.4 m2 (306 sq ft) Empty weight: 2,990 kg (6,592 lb) Max takeoff weight: 3,720 kg (8,201 lb) Powerplant: 1 × BMW 132K 9-cylinder air-cooled radial piston engine, 706 kW (947 hp) Performance Maximum speed: 311 km/h (193 mph; 168 kn) Range: 1,080 km (671 mi; 583 nmi) Service ceiling: 7,010 m (23,000 ft) Rate of climb: 5 m/s (980 ft/min) Wing loading: 98.2 kg/m2 (20.1 lb/sq ft) Power/mass: 0.167 kW/kg ( 0.101 hp/lb) Armament Guns: 1 × 7.92 mm (0.312 in) MG 15 machine gun 1 × 7.92 mm (0.312 in) MG 17 machine gun 2 × 20 mm (0.787 in) MG FF cannon Bombs: 2x 50 kg (110.231 lb) bombs |
Ads |
Arado Ar 234 pics 2 [08/10] - arado-ar-234-c-blitz-bomber-01.png (1/1) | Miloch | Aviation Photos | 0 | April 1st 17 04:04 PM |
Arado Ar 234 pics 2 [07/10] - Arado-Ar234-Blitz-2.jpg (1/1) | Miloch | Aviation Photos | 0 | April 1st 17 04:04 PM |
Arado Ar 234 pics 2 [06/10] - arado-ar234-blitz_27.jpg (1/1) | Miloch | Aviation Photos | 0 | April 1st 17 04:04 PM |
Arado Ar 234 pics 2 [05/10] - arado-ar234-blitz_26.jpg (1/1) | Miloch | Aviation Photos | 0 | April 1st 17 04:04 PM |
Arado Ar 234 pics 1 [10/13] - Arado Ar 234 1010b-2.jpg (1/1) | Miloch | Aviation Photos | 0 | April 1st 17 04:02 PM |
