EASA AD on SZD-55-1 "ATA 27 – Flight Controls – Elevator Control System / Vertical Tail – Inspection" Issued
Old April 11th 18, 07:29 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Default EASA AD on SZD-55-1 "ATA 27 – Flight Controls – Elevator Control System / Vertical Tail – Inspection" Issued
As expected, EASA issued the AD - 2018-0081 - 11 April 2018, with an effective date of 25 April, with 60 days to accomplish a one-time inspection. If discrepancies are noted, repairs must be completed before the next flight.
I include a link to the AD on the Transport Canada AD website http://wwwapps3.tc.gc.ca/Saf-Sec-Sur...U2018-0081.pdf . I imagine there is a similar link on an FAA site.
Old April 16th 18, 08:36 AM posted to rec.aviation.soaring
There's one in our club and it passed the inspection. Actually I would be interested to know if any 55's except the accident glider have had the opening on top of the fin enlarged as it did. I'm amazed that even one glider had been hacked away at in that manner.
Old April 16th 18, 12:47 PM posted to rec.aviation.soaring
Dan Daly[_2_]
From the AAIB report: "...One other SZD-55-1 glider in the UK fleet inspected by the AAIB, also appeared to have a marginally enlarged elevator slot, of which the owners were unaware. These findings indicate the possibility that such modifications may have historically been considered acceptable among glider owners...".
Old April 16th 18, 04:18 PM posted to rec.aviation.soaring
2G
The elevator hookup of the SZD-55 is not visible, so it cannot be inspected after assembly. The only means of verification is a positive control check.. The report does not mention if this was performed.
My old DG400 has a similar elevator hookup. DG, however, included a plexiglas inspection window in the tail so that the proper assembly could be verified. Nonetheless, I know of at least one flight where the glider was misassembled, and the elevator lever was jammed next to, and not in, the pushrod horn. The pilot flew the glider in this condition successfully, and did not learn of the problem until he derigged the glider. Having had one accident due to this exact situation (ASW19), I was particularly careful in ensuring this, and all other, assembly steps were properly completed. Perhaps the SZD-55 could use an inspection window like the DG400.
Old April 16th 18, 05:06 PM posted to rec.aviation.soaring
BobW
FWIW, this may be one of those situations when "It goes without saying,"
doesn't, so...
A positive control check isn't - or shouldn't be - "merely a control
resistance" check; it's (easily - and should be) also a "control position
check," as everyone who's ever built flying model airplanes intuitively knows.
Use the next unflyable day - or boring day at work - and play with paper
airplanes to help burn this "goes without saying" truism into your neurons!
Bob W.
This email has been checked for viruses by AVG.
http://www.avg.com
Old April 16th 18, 05:54 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Default EASA AD on SZD-55-1 "ATA 27 – Flight Controls –Elevator Control System / Vertical Tail – Inspection" Issued
neurons!
Or, for something fractionally more advanced than folded paper, try
making one or two of Chuck Marcos 'Easy Mini' catapult gliders. These
will teach you a lot about control surface effects and also fly well
enough to vanish upwards if you launch then into thermals.
See the AMA magazine "Model Aviation", May, 1999, pages 45-48 for a full-
size plan and instructions.
If you can't get hold of the magazine article, my website has copies of
the plan in various formats along with information about the tools and
materials needed to build them plus guidance on building and flying:
https://www.gregorie.org/freeflight/easymini/
Martin | martin at
Gregorie | gregorie dot org
Proposed SZD-55 EASA AD now out for comment - "Flight Controls – Elevator Control System / Vertical Tail – Inspection" Dan Daly[_2_] Soaring 57 April 19th 18 11:41 AM
DG-100 FAA AD 2009-20-04 Elevator Control Bearing Stand ContestID67[_2_] Soaring 6 October 4th 09 03:37 PM
Apollo 13 pix, batch one - "Apollo 13 CM interior during post flight inspection aboard Iwo Jima ap13-S70-15961.jpg" yEnc (1/1) [145K] hielan' laddie Aviation Photos 0 September 9th 08 04:44 PM
elevator /pitch control John Firth Soaring 5 November 6th 03 06:42 PM
News Flash: You don't need elevator control ! nowhere Soaring 42 November 5th 03 04:41 PM
