GliderLink - New team soaring app for airborne location sharing
Old April 26th 18, 04:11 AM posted to rec.aviation.soaring
Default GliderLink - New team soaring app for airborne location sharing
I'm excited to announce a new soaring app I've developed called GliderLink. The app shows your location and the location of nearby gliders on a moving map. You can see the other gliders' callsign, relative altitude, heading, and vertical speed. That's about it right now; it's very simple. The value of this app is that it allows you to quickly see where nearby gliders are, and whether they're in lift or sink. No more confusion on the radio trying to communicate to others where you are. With this app, all it takes is a glance. This enables team soaring, and increases safety by helping you be aware of where other gliders are. It could also be useful for lead/follow cross-country mentoring.
The app is free, and always will be. I developed it as a hobby and as a service to the soaring community. The app is for Android 4.3 and above, and requires Bluetooth LE (low energy, aka 4.0). I may make an iOS verison if there is enough interest. However, a used Android phone can be had for a song these days, if you don't want to wait.
Here's a screenshot:
https://glider.link/wp-content/uploa...5-768x1580.png
One unique thing about this app is that it doesn't require a cellular or Internet connection to share your location with others. Instead, it uses a device called a goTenna Mesh, which pairs to your phone/tablet using Bluetooth, and contains a separate radio that it uses to communicate with other goTennas. It's like a peer-to-peer airborne datalink. GliderLink uses the goTenna to directly send your GPS coordinates to other users of the app; once every 20 seconds. No cell towers, base stations, or servers are involved. You can put your phone in airplane mode, and still use the app and goTenna.
This is what a goTenna Mesh looks like:
https://glider.link/wp-content/uploa...naKeychain.jpg
You mount the goTenna Mesh in your cockpit, in a location where it will have line-of-sight to other gliders. I have mine velcroed to the underside of my canopy, but it also works well if you tape it to the end of your microphone boom where it can "see" out through the canopy. Here's what it looks like on the underside of my canopy:
https://glider.link/wp-content/uploa...nopy_below.jpg
In my testing, the maximum range of the goTenna Mesh is around 41.2nm (76.3km). However, the reception is not reliable at that range. In practice, you can get fairly reliable reception within about 10nm (18.5km), which is plenty. The app shows gliders in green if you've received a position update from them recently. If the app hasn't received a signal from them in a while, the glider will be shown in orange, then red if it's been a long time.
The cost of the goTenna Mesh is quite reasonable. They sell for about $72-90 each, depending on how many you buy at once. You can buy them from goTenna, or in outdoor stores like REI. Note that GliderLink uses the goTenna Mesh, not the original goTenna or the Pro. You can save $20 by ordering a goTenna Mesh from this link: https://www.talkable.com/x/IgisuY. This is their standard referral program, and I get a small reward from it. It would be nice way to say thanks for the app, but you don't have to use it if you don't want to.
The app can be downloaded right now from Google Play:
https://play.google.com/store/apps/d...der.gliderlink
The app will walk you through some setup, which involves requesting permissions, downloading a map for offline use, and entering your callsign in the settings. Downloading the map ahead of time ensures that it will be available while airborne, where you may not get cellular reception. Make sure the phone is on WiFi when you're downloading the map. It can use a lot of data if you're on a cellular connection. The larger the map area you select, the more data/storage will be used. Once setup, tap the little switch button in the corner of the screen to connect to the goTenna Mesh(make sure it's on) and start sending/receiving data. There is also a demo mode, accessible from the menu, that allows you to see a demonstration of what it looks like when you're flying with other GliderLink users.
There are many more features I'd like to add to this app in the future. Some possibilities include:
- Mesh networking: In addition to broadcasting your own location, the app could re-broadcast the locations of other gliders it sees, increasing the robustness and range of the network.
- Base station mode: If on the ground, the app could broadcast live weather data to glider pilots, such as wind speed and direction at the airport. It could also send the locations of any gliders it sees to a server on the Internet, so that people at home, or the FBO, can see where they are, sort of like glideport.aero.
- Lift marking: Recently used thermals could be marked on the map. Color coded glider tracks could also be shown, for visualizing wave/ridge/convergence lift.
- Mayday mode: Broadcast to anyone in range that you are in trouble, or need a retrieve.
- Internet connectivity: If you do happen to have an Internet connection while airborne, the app can use it to share your location as well, further increasing the robustness of the system.
I, and a few other pilots, have been testing the app around Hollister, California, and find that it comes in handy. I hope you do too, and I look forward to hearing what you think!
I have a website set up for GliderLink, but I haven't had a chance to put anything on it yet. You can check it later for more info: https://glider.link
Cheers,
Ben
Old April 26th 18, 06:16 AM posted to rec.aviation.soaring
Tom BravoMike
(...snip...)
Cheers,
Ben
Amazing! How exciting! I'm going to try it out and have already ordered my pair of goTenna mesh devices a few moments ago. It would have made such a huge difference last season (2017) when I was invited to follow another pilot, more experienced in the area, and 60% of my attention and pleasure was taken away by the constant effort to look for him in the sky. Thanks, Ben.
BTW, the mesh networking will be very useful in extending the range over a certain area. And how about an option to save the maps to an SD card?
Tom BravoMike
Old April 26th 18, 07:18 AM posted to rec.aviation.soaring
Thanks for trying it out, Tom! That's a good suggestion about storing the maps on an external SD card. I put it on my to-do list. There are a lot of improvements I want to make to map management in general.
Old April 26th 18, 07:50 AM posted to rec.aviation.soaring
Wyll Surf Air
Sounds like a very exciting new app. I wonder if this tech could be integrated into XCSoar? I know a lot of people already use the XCSoar app in flight so adding this technology would just make it even better.
Old April 26th 18, 02:29 PM posted to rec.aviation.soaring
Dan Daly[_2_]
In my testing, the maximum range of the goTenna Mesh is around 41.2nm (76..3km). However, the reception is not reliable at that range. In practice, you can get fairly reliable reception within about 10nm (18.5km), which is plenty. The app shows gliders in green if you've received a position update from them recently. If the app hasn't received a signal from them in a while, the glider will be shown in orange, then red if it's been a long time.
Cheers,
Ben
First, this sounds very interesting - similar to the Open Glider Network (OGN) but not requiring ground stations.
It says in the hardware specs it's a 1 watt UHF transmitter. I know the FCC limited PowerFLARM to .02 watts in the ISM band (CORE is 0.018w, Portable 0.010w) because of possible effects over a wide area given that it is line-of-sight. What frequency does this transmit on? UHF is 300 MHz - 3 GHz...
Old April 26th 18, 02:43 PM posted to rec.aviation.soaring
Paul Agnew
https://fccid.io/2ABVK02629
I found this with a quick search for FCC and GoTenna. Is this what you were asking about?
Paul A.
Old April 26th 18, 03:17 PM posted to rec.aviation.soaring
waremark
Can you explain for the technically illiterate? Is that a license to use it in the US? What about the UK?
Why have you chosen for this app not to work with output from a Flarm?
Old April 26th 18, 03:56 PM posted to rec.aviation.soaring
Sounds like it's an independent alternative to FLARM, and 90% cheaper. It only offers some of what FLARM offers though. Perhaps collision warnings can be added to the app. It still wouldn't include listening to ADS-B signals like PowerFLARM does. And it depends on other gliders in the area also using the same device. The more people use this instead of FLARM the less useful FLARM will be. Unless the different systems are cross-linked via a server, but that would require cellular data service. A consolidation of this app and the IGCdroid app (for logging and optionally real-time tracking) would also simplify things.
How long do the batteries last in this usage, in both the smartphone and the goTenna?
Old April 26th 18, 04:48 PM posted to rec.aviation.soaring
Jonathan St. Cloud
I would be interested in an iOS version! Very cool.
Cheers,
Ben
Old April 26th 18, 05:07 PM posted to rec.aviation.soaring
Let's not stop new solutions to preserve Flarm's market share. Add near traffic algorithms and Flarm units can take their place on the shelf next to barographs.
Support the U.S. Soaring Team Frank Whiteley Soaring 1 July 13th 14 04:07 PM
US Soaring Team eBulletin 21 John Seaborn Soaring 0 July 21st 05 05:14 PM
US Soaring Team eBulletin John Seaborn Soaring 0 November 20th 04 08:11 PM
GTA pilots on the US Soaring Team chris Soaring 2 September 1st 04 11:14 PM
U.S.A. Soaring Team Web Update John Seaborn Soaring 0 August 17th 04 05:14 PM
